Glass Coated Steel
I was wondering... is glass coated steel the same as stainless steel? And is it recyclable?
I am bidding on the demolition of a glass coated steel harvestore silo that has approximately 70,000 lbs of glass coated steel. I was wondering if this was recyclable and if anyone knew the going rate per lb or ton or however it is weighed? |
Re: Glass Coated Steel
if it's the same as the harvestore silos i've seen, it's just mild steel with a fiberglass coating to avoid any corrosion from the silage that's put in there. i think the only stainless steel you're going to see on them are the bolts. the harvestores here are all bolted, i would think it might be a headache demo wise, not going to be just a pushover and pick up the pieces. i would think to get any value out of the steel, you'll have to find a way to rattle the fiberglass from the steel. here, there is no market for recycle fiberglass, you pay 2 cents a lb to take it to the landfill.
someday, i'll be as patient as Nick. Last edited by dayexco; 11-29-2006 at 06:13 PM. |
I think that you're better off pricing this as junk. Check with your re-cycler. You could burn it off but a silo would be a very big, black cloud of smoke for a few cents per pound.
#4 | |
Trade: general contractor
Re: Glass Coated SteelQuote:
Mak Lucido |
| pvc coated rigid-stainless steel Ferric Chloride | Sluggo | Electrical | 5 | 10-12-2009 06:08 PM |
| Glass Block Transition | Paul_NJ | Ceramic & Stone Tile | 0 | 03-15-2007 08:14 AM |
| Broken Sliding glass door | sprinklerguy | Windows, Siding and Doors | 10 | 01-04-2006 04:58 PM |
| I can cut glass! | Teetorbilt | General Discussion | 9 | 11-24-2005 05:42 AM |
| Stone coated steel over heavy shakes? | dhebert | Roofing | 12 | 11-19-2004 10:50 PM |
