Frost Lines
Old 02-08-2006, 05:47 PM   #1
chrisherk's Avatar
Trade: electrician and excavation
Frost Lines
Anybody have any idea what the depth of the frost lines are? I cant find it in the International Residential Code, which New Hampshire uses. I always thought for a garage that has 2' of concrete sticking up' you need around 4' inthe ground (includes footing). The concrete guy was going to pour 4' walls and 2' of it is sticking out, which would've left 2'8" in the ground. Ive seen frost over 3' deep in this part of NH. Anyway I cant find a min. depth
chris
chrisherk is offline
Old 02-08-2006, 06:33 PM   #2
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Re: Frost Lines
Why will there be 2' sticking up??? Finished grade should be level with the top of concrete floor.
Anyways, around here we always dig our frost footers 3' deep.
rino1494 is online now
Old 02-08-2006, 06:38 PM   #3
bassmaster's Avatar
Trade: Home Improvement/ Handyman Services
Re: Frost Lines
I Think in CT it is 42", jmic - would probably know for sure.
A bad day on the water is better than a good day at work !
BASSMASTER
bassmaster is offline
Old 02-08-2006, 06:38 PM   #4
chrisherk's Avatar
Re: Frost Lines
2' is the finished grade around the whle house because of the height of the bulkhead. where are you penn? this job is in northern NH I was thinking 4' but i would like to see something in the code.
chris
Old 02-08-2006, 06:38 PM   #5
jmic's Avatar
Re: Frost Lines
This area in Ct. goes by 42" for frost.
Joe
jmic is offline
Old 02-08-2006, 06:42 PM   #6
chrisherk's Avatar
Re: Frost Lines
Is that what the state code, or local inspector says?
Old 02-08-2006, 06:45 PM   #7
jmic's Avatar
Re: Frost Lines
Chris,
Is what you're calling a bulkhead the little pc. of foundation wall between garage doors? Anyways from your finish garage slab elevation you should have probably ilike what your thinking 48" to bottom of your footings for frost.
Joe
jmic is offline
Old 02-08-2006, 06:46 PM   #8
PipeGuy's Avatar
Trade: underground
Re: Frost Lines
From http://www.bow-nh.com/codeenforcement.asp
BOCA CODES:
As of 2002, the Town of Bow uses the 1984 BOCA Codes for residential buildings, and the 1999 BOCA Codes for commercial buildings.
Roof Loads: Both live load and snow load are 40Lbs/Sq Ft--- Commercial: 45-50 Lbs/Sq Ft
Ground Snow Load: Commercial: 75-85 Lbs/Sq Ft
Wind Pressure: 25 Lbs/Sq. Ft---Commercial 80-90 Lbs/Sq Ft
Seismic Zone:2 --------------------------Frost line depth: 3 Ft.
PipeGuy is offline
Old 02-08-2006, 06:49 PM   #9
jmic's Avatar
Re: Frost Lines
Couldn't really tell you for sure, it's just common knowledge of what everyone does and the inspectors expect, so it must be code
Joe
jmic is offline
Old 02-08-2006, 06:55 PM   #10
PipeGuy's Avatar
Trade: underground
Re: Frost Lines
see also http://met-www.cit.cornell.edu/reports/RR_96-1.html
PipeGuy is offline
Old 02-08-2006, 07:03 PM   #11
Vagitarian
rino1494's Avatar
Re: Frost Lines
Chris,
We call that a keyway.
To us, a bulkhead is vertical footer that runs b/n grade change elevations.
Old 02-08-2006, 07:05 PM   #12
chrisherk's Avatar
Re: Frost Lines
Chris,
the bulkhead is the outside basement stairs into the basement. For some reason they set that 2' down from top of foundation. That right there sets the grade around the whole house (flat lot).I just found in the Mass code, it says 48". I knew i was right, this concrete guy is putting garages and breezeways in too shallow. thanks, jmic
chris
Old 02-08-2006, 07:09 PM   #13
PipeGuy's Avatar
Trade: underground
Re: Frost Lines
found it
"Extreme depth of frost penetration (in meters)"
http://www.ngs.noaa.gov/PUBS_LIB/GeodeticBMs/#figure13
PipeGuy is offline
Old 02-08-2006, 07:11 PM   #14
chrisherk's Avatar
Re: Frost Lines
I guess every body calls things different, I always thought a keyway is the tie-in from the bottom of the wall to the top of footing, to keep the wall from sliding off the footing. But what do i know.
Old 02-08-2006, 07:13 PM   #15
chrisherk's Avatar
Re: Frost Lines
Originally Posted by PipeGuy
found it
wow, i'm impressed
Old 02-08-2006, 07:22 PM   #16
PipeGuy's Avatar
Trade: underground
Re: Frost Lines
I was kinda' surprised to see it. Down here the frost line is only 1/2 a meter but everything gets 4 feet of cover. What's that, a 2:1 safety factor?
PipeGuy is offline
Old 02-08-2006, 07:30 PM   #17
Tom R's Avatar
Re: Frost Lines
Yeah, - - what I call a 'keyway' is a slot along the top of the footing to help prevent sliding.
Cool map, Pipe.
http://www.tr-built.com
Tom R is offline
Old 02-08-2006, 07:33 PM   #18
Vagitarian
rino1494's Avatar
Re: Frost Lines
I guess we are talking about poured walls here then. I haven't seen too many masons use a slot in the footer around here. Most use rebar sticking up.
Old 02-08-2006, 07:44 PM   #19
jmic's Avatar
Re: Frost Lines
We call a keyway a 2"x2" groove that runs around the footings under where the walls will be sitting so when the walls are poured they lock into the footings.
We just call these steps but have heard them refered to as bulkheads, I was just curious as to what Chris was refering to.
Joe
jmic is offline
Old 02-08-2006, 07:49 PM   #20
jmic's Avatar
Re: Frost Lines
chris
Ok now I see what you're calling a bulkhead, we use precast Bilco Door Units, the Co. just comes and bolts them to foundation
Joe
jmic is offline
Frost inside the attic? SOSSW Roofing 22 04-03-2009 08:26 AM
Getting super straight lines. metomeya Painting & Finish Work 16 02-17-2008 12:17 AM
Building Home near power lines ButlerDesigns Construction 3 04-22-2007 11:25 AM
Bonding Plastic Water/Gas Lines? jevorik Electrical 3 12-29-2006 12:24 AM
Quickbooks - Accounts and Tax Lines Tileworks Technology 2 01-15-2006 04:26 PM
