French Drain
What do you consider a French drain?
This is another of those terms that seem to have different meanings in different areas. Nick |
Vagitarian
Re: French Drain
Any ditch that contains pipe and stone to carry away water.
Trade: underground
Re: French Drain
To me french drain = dry well; they don't drain to daylight but merely percolate into the surrounding ground.
Re: French Drain
IMO French Drain / Farmers Drain being the same is just diverting ground water from one location to another without pipe by means of native stone - rocks. I've heard one of the reasons farmers built walls was to allow water to follow along them, of course another was to get rid of the dam rocks they kept plowing up, then also to keep the heards in. Then you could argue they wanted to create boundries.
Re: French Drain
I'm with Rich. They work great in sand, not so sure about other substrates.
#6 | |
Re: French Drain
When I use the term "French Drain" I think of removing water not storing water the way a dry well might.
A french drain would be to intercept water from either below grade as with ground water or from above grade in order to.... I don't know, drain rain water from a lawn that is too flat. And it's great cause sometimes they come with baguettes.
| Condensate drain question | airwick | HVAC | 6 | 07-23-2007 07:48 PM |
| Tub install and drain in slab | Mpeters | Plumbing | 2 | 03-04-2007 05:43 PM |
| French Drain | Cole | Landscaping | 6 | 02-21-2007 07:52 AM |
| French drain question | 72chevy4x4 | Construction | 4 | 11-01-2006 10:46 PM |
| ...continued...garage floor drain progress | carlspackler | Plumbing | 0 | 05-27-2006 02:54 PM |
