Trade: Exteriors
Foundation Question
Hey guys, what kind of foundation would you use for and addition on an old farmhouse in minnesota. Doesn't want a basement on the new addition. Just adding one big family room 30 x 20 and an attacted gargage 30x 40. The addition will be in between the garage and existing house. I've heard of shallow foundations but any info would be great. Thanks.
Cat385
Trade: excavating
Re: Foundation Question
Not sure on your codes but here in wisconsin if you would have to put in a 4' frost wall with 8" footings or as they say down south footers
NE Ohio Excavator
Trade: Excavating, Septic, Trenching, Landscape Excavatio
Down south of you in Ohio it is also footers. We usually are at 36" in depth for frost code and footer size is 8" thk x 18"wide for non coded building and 8" x 24" minimum for most coded/inspected jobs. You need to know what your local code is if any and what the max. frost depth is in your area. Most jobs that are being built to code have drawings/plans with specs. on footers.
Alan |
Midnight
Trade: Excavating, Grading, Demolition, Underground Utilities
If it was independent of the house you would be able to use a floating slab, but in this case you would absolutely have use frost footing foundation due to the nature of the construction. In the winter the frost heave would separate your proposed construction from your existing. You will never get an approval from the building inspector with out frost footings.
"It is what it is" |
You've been data mining
here for two years? Who are you, and what do you do really?
#7 | |
Trade: Masonry
Re: Foundation QuestionQuote:
Probably a local Mason could help you out with that. |
| Question about building layout / foundation | greg9706 | General Discussion | 2 | 08-19-2007 09:01 PM |
| 32 x 50 Pole Barn foundation pad question... | Big_Ben | Excavation & Site Work | 7 | 05-15-2007 11:58 PM |
| foundation question | Scott Young | General Discussion | 4 | 03-04-2007 10:56 PM |
| foundation question | haskl33 | Masonry | 6 | 12-09-2006 07:05 PM |
| Garage foundation question??/ | Sellncars | Masonry | 7 | 07-15-2006 07:05 PM |
