Forgot How To Square Up A Foundation
Old 07-02-2011, 08:30 AM   #1
burntside bob's Avatar
Trade: excavating
Rewards Points: 95
Question
I forgot how to square up a foundation and can not find my notes on this topic. Its been a while since I did this. Real busy you know
the foundation is 24 x 32
a/b is 24
c/d is 24
a/c is 32
b/d is 32
how do I get the a/d and b/c criss cross meassurement to square the foundation?
burntside bob is offline
Old 07-02-2011, 08:35 AM   #2
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Forgot How To Square Up A Foundation
Pythagorean Theorem
All the diggers I know use lasers...
-Steve
TimelessQuality is offline
Old 07-02-2011, 08:39 AM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 9,910
a/b is 24
c/d is 24
a/c is 32
b/d is 32
a+b=c
24+32=c
576+1024=1600
Sqr. root of 1600 is 40.
Or, you could just measure all four sides to verify the pairs are equal (a-b and c-d are both 24, b-d and a-c are both 32) then measure both diagonals and see if they (a-d and b-c) are equal.
Chuck Norris can start a fire by rubbing two ice cubes together.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
S.R.E. (07-02-2011)
Old 07-02-2011, 08:48 AM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 300
Originally Posted by 480sparky View Post
a+b=c
24+32=c
576+1024=1600
Right on Sparky, pretty old school , but it works all the time.
Randy Bush is offline
Old 07-02-2011, 09:04 AM   #5
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
Send a message via AIM to ApgarNJ
Get a calculator and it will tell you what the diagonal should be when you give a length/width.
Depends on the size we normally do smaller addition foundations, so the mason squares it up good, but when we build the deck. I use the 3,4,5 or 6,8,10 method of squaring, usually it's attached to a house, so you can't always go off the corner to corner as there aren't 4 perfect corners.
ApgarNJ is offline
Old 07-02-2011, 10:54 AM   #6
GettingBy's Avatar
Rewards Points: 6,486
Yes. No calculation involved.
If the diagonals are not equal within reasonable tolerance limits for this kind of project then you'd have to measure each angle to find the problem.
For a home-built picture frame, diagonals equal to each other within 1/16" is probably OK so I'd think acceptable tolerances on something this large could be +/- 1" or so. Civil engineers using steel tapes actually correct for tape sag, tape tension, and the effect of ambient temperature on the length of the tape.
Maybe the building codes or housing inspectors say something about this.
GettingBy is offline
Old 07-05-2011, 09:43 AM   #7
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
X2, quickest and easiest method.
woodchuck2 is offline
Old 07-05-2011, 12:28 PM   #8
Kent Whitten's Avatar
Rewards Points: 2,040
In the bind, a simple 3/4/5 in multiples will suffice.
Meaning
6/8/10
9/12/15
etc. Or in your case
24/32/40 as sparky states.
The last number means your diagonals. First two your sides and front/back measurements.
SalmonFallsCabinetry.com
Kent Whitten is offline
Rain floated foundation Morning Wood General Discussion 11 03-31-2010 06:36 AM
Is Foundation Strong Enough For 2nd floor addition? Vince10 General Discussion 11 02-23-2010 01:27 PM
Foundation Question kuponoconstr Construction 1 02-17-2010 08:04 AM
cut an opening in foundation Martydukes Masonry 18 10-04-2008 01:18 AM
Anyone have experience with Thoroseal to waterproof bsmt foundation? Jim S. Construction 1 08-26-2008 11:53 AM
