#21 |
mics_54
Guest
Posts: n/a
Re: Footer Slab Question
When in nonexpansive soils (NFS) an insulated slab on grade might be legal. It depends on local codes (if applicable) However if the existing house in on a block foundation one may assume a similar foundation on an addition might be recommended.
#22 |
DJ9222
Guest
Posts: n/a
In my part of the world if you are building space to be used as LIVING space it must have footings snd stem wall below frost line (36").... good luck and check with building inspector........
#23 |
WarriorWithWood
Guest
Posts: n/a
It'll never fly around here, I don't care how deep the original is. You need to go 36" deep minimum.
#24 |
mics_54
Guest
Posts: n/a
I checked the pittsburgh website and didnt see any ammendments addressing the issue. If pittsburgh uses the 2006 irc and didnt adopt any local ammendments then I have to assume that the irc code R403.3 for frost protected foundations may apply. There are stipulations that the structure is a heated space. Frost protected insulated foundations may not be used on outbuildings, garages, car port or attached to buildings with crawlspaces or basements. The OP will have to determine if the code applies to his circumstances. The pittsburgh website http://www.city.pittsburgh.pa.us/BBI/ indicates the area has an Air Freezing index of 1500 which is the least value of the air freezing indexes listed on the irc chart R403.3
Oh and for New York... it is the same. http://www.dos.state.ny.us/code/rcfaq.htm#footings Q.Does the residential code require footings to frost for all buildings? A. No. Section R403.3 entitled “Frost protected shallow foundations” provides that for buildings where the monthly mean temperature of the building is maintained at a minimum of 64ºF (18ºC), footings are not required to extend below the frost line when protected from frost by insulation in accordance with Figure R403.3(1) and Table R403.3. EXCEPTIONS: 1. No foundation not so protected may be attached to frost-protected shallow foundations. 2. Unheated garages, porches, utility rooms and carports shall not be permitted to be attached to dwelling units with a frost-protected shallow foundation. Materials used below grade for the purpose of insulating footings against frost shall be labeled as complying with ASTM C 578. Last edited by mics_54; 07-11-2009 at 08:40 PM. |
| The Following User Says Thank You to For This Useful Post: |
#25 |
JDC Owner
Guest
Posts: n/a
Thanks for digging some info mics, I was heavily researching FPSF systems for awhile now. I don't know if one will qualify though, the addition is going to be attached to a heated basement and unheated garage. Plus the soil seems very susceptible ( alot of silt ), but I'll make some calls and see if it checks out.
#26 |
mics_54
Guest
Posts: n/a
If it's attached to a basement and unheated garage it must be on a footer below frost line. (36" in Pittsburgh)
#27 |
rino1494
Guest
Posts: n/a
PA building code requires a foundation wall of no less than 40". Using block, that is 5 courses, plus a 8" footer. Also, the footer must be at least 20" wide.
Also, you must be at least 3' in the ground. So, if your wall is sticking out of the ground pretty good, you may need to add extra courses. For approval, just submit plans for 5 courses. |
#28 | ||
WarriorWithWood
Guest
Posts: n/a
Re: Footer Slab QuestionQuote:
#29 |
jkfox624
Guest
Posts: n/a
Slabs dont fly around here no matter how you do it. We always shoot for 40" minimum to top of footer minimum 2' wide 8" deep with 2 rows rebar. Your gonna need 2" foundation foam on inside of stem wall we usually use a poly foil double bubble insulation under the slab.
#30 |
WarriorWithWood
Guest
Posts: n/a
Yup, same here. It's been a while so I was stuck on the 36" but it is 40" here now.
EDIT: I'm assuming you mean a slab with no footings. Last edited by WarriorWithWood; 07-12-2009 at 10:20 AM. |
#31 |
rbsremodeling
Guest
Posts: n/a
Re: Footer Slab Question |
#32 | |
mics_54
Guest
Posts: n/a
#33 |
WarriorWithWood
Guest
Posts: n/a
#34 |
jkfox624
Guest
Posts: n/a
We usually get 6+ feet a year depending on how the lake effect falls. To the NW a bit just into NY state they get hammered, one place got like 23' last year. And yeah sorry shouldnt have said any slab meant slab on grade or frost protected slabs are a no go, it has to have footings below frost line.
#35 |
cdkyle
Guest
Posts: n/a
Old school rule of thumb: Footings should be twice as wide as wall and minimum of 6" below frost line. Shouldn't have a problem if you conform to this rule, but I would check with local AHJ.
#36 |
mics_54
Guest
Posts: n/a
forget it.
| Another wood subfloor over concrete slab | GreenBuilder | Carpentry | 3 | 05-08-2008 01:20 PM |
| Question regarding concrete slab | TennesseeBrian | Concrete & Paving | 5 | 01-06-2008 09:11 PM |
| Demo a foundation under a radiant heat slab without disturbing the slab...? | wackman | Remodeling | 18 | 04-02-2007 12:38 AM |
| Brick Footer and Water Proofing | emtaboy | Excavation & Site Work | 24 | 07-24-2006 09:48 PM |
| Basement slab question | n74tg | Masonry | 5 | 05-26-2006 04:38 PM |
