Fill Tip
Old 04-15-2006, 09:29 PM   #1
jmic's Avatar
Fill Tip
Just a little something I always do whenever I get a job where we are filling in excess of 3'. I take 6" solid Hancore pvc pipe and run them 5 -6' apart around the inside perimeter of the foundation walls ( vertically ) usually keep them about 4" below slab sub grade the bowling the last 4"with the fillon top of the pipe so you have sort of a funnel look. Then when they pour the slab the concrete runs down the pipe to the footings creating a pillaster to help support the slab should the dirt settle any more ( yes we do use plate compactor with 12" lifts ) Oh yeah, the concrete guys also run a band of rebar over the top of these along with the wire mesh. If there's any footings needed for lolly columns in a garage I'll use a pc. of 18" corrugated plastic drainage pipe cut to length needed and fill that with concrete also.
Joe
jmic is offline
Old 04-15-2006, 09:54 PM   #2
denick's Avatar
Re: Fill Tip
Joe,
Thanks for the idea. Your a pretty smart guy.
Nick
denick is offline
Old 04-16-2006, 09:02 AM   #3
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Re: Fill Tip
Good idea, but we never put footings on compacted material. We will just dig down to solid ground and the mason will lay a wall up to the top of the footing. We did one job years ago on a slope that had 22' of pitch just where the house was. The one side of the house had 16 courses of block just to get to footer height.......plus 13 courses for the house.
rino1494 is offline
Old 04-16-2006, 08:47 PM   #4
jmic's Avatar
Re: Fill Tip
Rhino,
Think you misread my post, I never said or ever put footings on compacted fill. The tubes run down on footing of walls, the footings for lolly's go down to virgin soil.
Joe
jmic is offline
Old 04-17-2006, 06:16 AM   #5
Vagitarian
rino1494's Avatar
Re: Fill Tip
Are you talking about basements or garage's....or both ?
So, you are saying that when you have to use a wall to bring it up to footer height, that you fill the inside of it with dirt and then compact it ?
rino1494 is offline
Old 04-17-2006, 06:23 AM   #6
jmic's Avatar
Re: Fill Tip
Rhino,
No . I'll explain later
Joe
jmic is offline
Old 04-17-2006, 07:25 PM   #7
jmic's Avatar
Re: Fill Tip
Don't know if this will come out, but just so everyone knows this is why I do what I do and I'm not a Draftsman.
Joe
jmic is offline
Old 04-17-2006, 07:27 PM   #8
jmic's Avatar
Re: Fill Tip
Rhino,
Hopefully this will give you a clue as to what I was talking about in the 1st post.
Joe
jmic is offline
Old 04-17-2006, 08:11 PM   #9
tgeb's Avatar
Re: Fill Tip
I understood your first post perfectly Joe.
You draw more better than I do.
Around here we put grade beams in the garage slabs and support them that way. No one takes the time to do compaction. At least that's the way with the tract homes.
www.gebcon.com
tgeb is offline
Old 04-17-2006, 08:33 PM   #10
jmic's Avatar
Re: Fill Tip
Tgeb,
Last week I filled a 1 car garage 16' x 22' on the back side with 12' of fill compacted in 12" lifts. The front was around 5' deep.
Joe
jmic is offline
Old 04-17-2006, 08:47 PM   #11
tgeb's Avatar
Re: Fill Tip
Often times we have trouble locating fill that is suitable for compaction.
It will be too wet, to much oganic mixed in, or to rocky.
Do you have it tested in garages when you fill them this way?
www.gebcon.com
tgeb is offline
Old 04-18-2006, 05:51 AM   #12
Vagitarian
rino1494's Avatar
Re: Fill Tip
Oh, i see now Joe. I thought you were talking about basement footers, now I see that you were talking about the garage's and frost walls.
Anyway, do most of you guys use dirt to fill the garage and frost walls ???
We use mine rock, which is basically shale on top of coal. We buy it pretty cheap, for only $30 a load. If you look good enough, you might be able to find some coal in it too.
rino1494 is offline
Old 04-18-2006, 06:09 AM   #13
jmic's Avatar
Re: Fill Tip
Rhino,
Wow $30 / ld. what a bargain! The best I've come up with is $250 / ld. for screened fill up around where we work
Joe
jmic is offline
Old 04-18-2006, 10:07 AM   #14
dayexco's Avatar
Re: Fill Tip
rino, we fill a lot of garage areas with clay or granular fill. BUT, we insist they hire a soils engineer to take density tests as we progress to be able to document it was done properly, and that the soil we're using to fill with will bear the load of the structure they're building on it
dayexco is online now
Where to get fill dirt robertc65 Excavation & Site Work 24 02-25-2009 10:50 PM
Quickest, best way to fill prefinished hardiboard trim nailholes? pinesol Painting & Finish Work 8 07-31-2007 07:47 AM
Flowable fill? ruskent Excavation & Site Work 18 01-16-2007 06:37 PM
Slab on Grade fill options? James Ellis Construction 10 10-24-2006 01:55 AM
Wood fill for cabinets Tornado65 Carpentry 2 11-02-2005 08:17 AM
