FH 220-LC Track Motor Hydraulic Pump Leaking
Please can someone help me out with some advice.
I have recently (today) bought a FH220-LC age 1996 and this has done 8800hours. The hydralic oil is leaking heavily from one of the track motor hydraulic pumps. Firstly I am looking to find out what is the best way to disassemble the unit to identify the leak and secondly if it is a seal on the hydraulic pump is this a relatively easy task to do?? I very much appreciate some valuble knowledge out there. Regards Si |
Re: FH 220-LC Track Motor Hydraulic Pump Leaking
I am not familiar with that particular machine, but my experience with Hydraulic pumps would say this one needs a rebuild, the seals should be internal.
But it could be a cracked, loose, or busted line. Till you can get in there and look at it, who knows. Wish I could be of more assistance. Good luck with it. |
Thanks very much for your reply. Will hopefully get something from someone that may have experienced this???
You might get some more responses if this was in the Excavation and Site Work area.
I'll see if I can get one of the Moderatorsto move it for you. |
PRO
Trade: CGC Concrete
Not to be an arse, but why would you buy a machine with a leaky drive motor? Did you get a great deal?
Well how much would you have paid for it and I will tell you if i was successful in getting a good deal??? Remember now I am a Scotsman!!!!!!
Thanks for the advice
Hello High Land Gold,
Welcome to the site. I don't know we have had an excavator from Scotland before. I for one would like to hear how things are done over there. Their name is MacKay ??? My wife is of Scottish descent although she doesn't know much of the family history. Our nieghbors are here from Scotland, the wife is a traveling nurse and they move around the country. They seem to like it here and are looking at staying. Your excavator, you said the "track motor hydraulic pumps" what you are describing sounds like the hydraulic motor for the drive? not the pump? The pumps should all be mounted on the pump drive behind the engine? You then have a hydraulic motor that would be mounted on the chassis in a protective cover down at track height near the large track drive on the undercarriage. The hydraulic motor should just be a unit about 6" to 8" squarish in shape with hoses attached to it. If this is leaking badly it is seals, o-rings or split. This is a pain because this is a major hydraulic line at the lowest point of the machine and you can loose a lot of hydraulic oil at one time. Maybe you could describe it more?
Nick "Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein Last edited by denick; 05-12-2008 at 06:00 PM. |
| What contractor would look at this problem? (Water leaking from doors/windows...) | Knyte260 | General Discussion | 34 | 01-02-2008 04:53 PM |
| Graco Endurance Pump | Brockster | Painting & Finish Work | 2 | 09-22-2007 07:42 PM |
| 4 Sale: 1/2 HP Wayne Porta Pump | Terrence | Pressure Washing | 0 | 04-18-2007 10:43 PM |
| Well Pump Depth Question... | thepawnshop | Plumbing | 9 | 08-13-2006 09:01 PM |
| What Pump to Use? | dblommel | Painting & Finish Work | 0 | 03-05-2006 12:15 PM |
