Excavate Garage Floor My Only Option?
Old 12-03-2008, 01:57 PM   #1
EDHC's Avatar
I've got a garage conversion contract coming up in the spring (mountains of Northern California) and the designer is telling me that in order to raise the floor level of the garage up 14 inches to the level of the raised floor of the residence is for me to remove the garage slab and excavate the soil beneath so that there will be 18 inches of vertical space between the soil and the bottom of the new joists. I'm concerned that this will endanger the existing footings. The building department wasn't much help and said "go look on the web for an alternate solution." I'm prohibited from using active ventilation (fans). Using 2x10 joists and leaving the slab in place, I will be left with only 3-1/2 inches clearance between the bottom of the joists and the slab. Any ideas on how I can avoid hammering out the slab floor while ensuring good ventilation to keep it nice and dry?
EDHC is offline
Old 12-03-2008, 05:16 PM   #2
tgeb's Avatar
Re: Excavate Garage Floor My Only Option?
Put in the new floor with wood framing and use Icynene (foam) insulation, no ventilation necessary.
www.icynene.com
www.gebcon.com
tgeb is online now
Garage receptacle ChuckEA Electrical 21 04-27-2011 07:45 PM
Vapour barrier between garage and living area?? big builder Insulation 18 12-23-2008 02:25 PM
Custom Garage Doors Just-In-Time Carpentry 23 12-08-2008 11:04 PM
Epoxy Garage Floors RoSSco Painting & Finish Work 8 09-04-2008 11:00 AM
Help - Garage floor/room addition drbrsjr General Discussion 10 04-26-2008 09:36 PM
