#21 |
Re: Engine Loosing Oil?
Well I finally got to it. Put some sealant inside the ends of the hoses and put new hose clamps on. We haven't had a leak all week long. To change the actual hose you needed to remove the fuel pump and a lot of the rocker arms and injector linkage. There didn't seem to be any cracking, they were just loose. The clamps were the plastic clip type.
Nick "Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein |
#22 |
Just knew you could do it Nick!
#23 |
Moderator
Good job!
#24 |
Trade: genaral contractor
Have You Checked Oil Returns In Head Sometimes they sludge up (close off) which doest let oil drain back to oil pan Valve cover fills up Has to go some where !!! Pull Valve cover dump oil in top of head see if oil drains back to oil pan quick enough if not wacth were oil goes to and clean out hole (drain Holes From Head to oil pan) Just a Thought
used to make a soultion myself 1 qt gas,1qt k1 add to engine run for a few miles drain oil change filter refill usually works preety good may try prouduct called GUNK same dirrections GOOD LUCK !! |
| Which Detriot Diesel engine do you guys think is the best one? | 4theroc | Excavation & Site Work | 10 | 03-05-2007 01:50 PM |
| Loosing pressure. | dumplin1078 | Plumbing | 9 | 01-05-2007 04:01 AM |
| It's time for you to try Search Engine Marketing... FOR FREE! | Nathan | Marketing & Sales | 12 | 12-19-2006 06:08 PM |
