Engine Loosing Oil?
Old 09-07-2006, 08:03 PM   #1
denick's Avatar
Engine Loosing Oil?
We have an 86' F600 with a 8.2 liter Detroit Diesel engine.
We are having a problem with the engine blowing oil out somewhere near the top of the engine.
It happens sometimes, like a week or two apart. it varies in severity from a little to a gallon.
There is no loss of compression. there is no blow-by. there is no pressure in the breathers. The engine isn't burning oil. I can find no broken hoses or tubes.
we have changed the valve cover gaskets and the breathers.
Anyone have any IDEAS?
Nick
"Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein
denick is offline
Old 09-07-2006, 08:18 PM   #2
mdshunk's Avatar
Re: Engine Loosing Oil?
What I can't figure out is how you can lose so much oil out of the top end, and not have any in the breather or air cleaner. It can't be due to unusual top end pressures in that case. You're looking for a genuine leak, and not something blowing out under pressure. Might pay you to have the engine steamed off and keep a close eye on it. That's always pinned it down for me.
mdshunk is offline
Old 09-07-2006, 08:23 PM   #3
jmic's Avatar
Nick, How often do you have to add oil?
Joe
jmic is offline
Old 09-07-2006, 08:25 PM   #4
jmic's Avatar
Nick,
Does it have a JAKE ?
Joe
jmic is offline
Old 09-07-2006, 08:25 PM   #5
Teetorbilt's Avatar
You need to nail down the cause. There is nothing that any technician hates worse than an intermittant problem.
Maybe it short/long drives. Loads. Ambient temps. You have to look for a pattern.
My experience is limited to the 71 and 92 series used in yachts. Also obsolete.
Albert Einstein
Teetorbilt is offline
Old 09-07-2006, 08:27 PM   #6
R&S Exteriors's Avatar
Trade: Exterior Construction
Is it actually leaking up top or could it be blowing up there?
Have you checked the oil filter. I had an oil filter that was not on properly once and it would leak then stop leaking
R&S Exteriors is offline
Old 09-07-2006, 08:34 PM   #7
denick's Avatar
No Jake Brake.
Never had to really add oil, just oil changes.
The oil trail seems to be from the top down.
Cannot find a pattern.
Nick
denick is offline
Old 09-07-2006, 08:45 PM   #8
How about the oil pressure sending unit or if it has emission through an emission line coming from valve cover or manifold?
Old 09-07-2006, 08:47 PM   #9
mdshunk's Avatar
I was thinking along those lines, sorta. Some of those had a balance tube that connected the back of both heads, too. We're just guessing, anyhow. Steam it off and look for where the fresh leak is.
mdshunk is offline
Old 09-07-2006, 08:50 PM   #10
denick's Avatar
Oil pressure sending unit is at the very back side of the block and it doesn't seem to be the problem. Although We have not been able to find the leak.
Thanks for the aggressive thought guys.
Nick
denick is offline
Old 09-07-2006, 11:45 PM   #11
dayexco's Avatar
seal out or going out on your turbo? they take oil from the pan to lubricate/cool the bearings. if the seal goes out, they'll suck oil right thru the engine.
dayexco is offline
Old 09-08-2006, 06:05 AM   #12
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
If a seal is bad in the turbo then you'll blue smoke in the exhaust.
rino1494 is offline
Old 09-08-2006, 10:25 AM   #13
Dave-Raleigh's Avatar
Trade: Residential remodelling
Steam clean the engine off and pour a oil dye in the oil. The leak should show up prety easy then. Do a google search for 'oil dye' A good parts place might have it too.
Dave-Raleigh is offline
Old 09-18-2006, 09:51 PM   #14
jojo's Avatar
Trade: excavating
does the turbo have an oil line going to it,,could be cracked or loose...
jojo is offline
Old 09-18-2006, 10:07 PM   #15
dayexco's Avatar
denick, you must know by now....what was the verdict on this engine?
dayexco is offline
Old 09-18-2006, 10:16 PM   #16
denick's Avatar
Unfortunately I haven't gotten to that truck yet. I replaced the rear-end in my van and did a complete brake job on our dump truck and all the other small stuff that has come up in the last 5 weeks. While trying to get some productive time in on jobs, estimating, billing (which my wife spent tonight letting me know how much I haven't gotten done in these departments.
I spent a lot of time trying to pull the wetlands job together.
I hope to start on it by the end of the week
Nick
denick is offline
Old 09-23-2006, 08:26 PM   #17
denick's Avatar
Well I finally got time to work on that truck. I cleaned the top of the engine . I then ran the engine between 1800 to 2300 rpm for almost an hour. I kept checking. Nothing! I idled the engine down and went into the shop. I came back out and climbed up on the wheel to try and figure this out. There was a puddle up on the air intake.
There is a metal tube coming out the head that goes to the fuel pump. It is connected to the pump with a 3/4" rubber hose. through the tube and hose runs a rod that I think opens the rack for the injectors. Out of the hose was running a steady line of engine oil.
Next week off comes the valve cover to see what's going on.
Nick
denick is offline
Old 09-23-2006, 09:28 PM   #18
Bob
Excalibur's Avatar
Trade: Truck driver / Equipment operator
Hmmm.. a Detroit leaking oil... how interesting. With the old 71 and 92 series engines if it didn't leak oil then you knew that something was wrong. If your 8.2 is like its ancestors, it should be healthy as a horse!
Bob
Excalibur is offline
Old 09-24-2006, 01:04 AM   #19
Teetorbilt's Avatar
Excalibur, in the marine industry they always painted them white. Makes all of the drips show up better.
Anybody know of a diesel that doesn't leak? I'm familiar with most.
Albert Einstein
Old 09-24-2006, 05:01 AM   #20
Moderator
Double-A's Avatar
Never had problems with the smaller Yanmars.
New York Times, July 20, 2006
Double-A is offline
Which Detriot Diesel engine do you guys think is the best one? 4theroc Excavation & Site Work 10 03-05-2007 01:50 PM
Loosing pressure. dumplin1078 Plumbing 9 01-05-2007 04:01 AM
It's time for you to try Search Engine Marketing... FOR FREE! Nathan Marketing & Sales 12 12-19-2006 06:08 PM
