Drain Tile
Old 06-13-2008, 08:30 AM   #1
Thunker67's Avatar
Question
Drain Tile
Getting ready to run some drain tile in front of my house. What's the best size/depth of trench, & what should I put in/around the tile? Pea gravel?
Thunker67 is offline
Old 06-13-2008, 03:33 PM   #2
Re: Drain Tile
Could you make the question
a bit more vague?
Don't be so specific, it ticks
folks off when you bog things
down with so many details.
neolitic is offline
Old 06-13-2008, 04:50 PM   #3
jmic's Avatar
Re: Drain Tile
What is it you're trying to drain ?
Joe
jmic is offline
Old 06-14-2008, 06:11 AM   #4
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Re: Drain Tile
I take it that you are putting a drain in your yard as a curtain drain. As far as depth, that depends on the soil and how the water permeates through the soil. You may have to go 2' or even 8'. We use what is called 2B which is 2" minus. We line the bottom with a thin layer of stone, install the perf pipe then fill up the rest of the way with stone. If you are gonna cover it up, with dirt, put down a layer of filter cloth or hay first then cover. If you have a lot of run-off and you are trying to catch that, then leave it open.
rino1494 is offline
Drain Tile Spacings for Farms golfing123 Excavation & Site Work 7 02-17-2008 03:36 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
drain tile question bobbrown Construction 5 09-05-2006 07:52 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
