Vagitarian
Dragging Trench Boxes
How do you guys drag your boxes in the trench ?
We hook about a 8ft piece of wire rope on the box with clevices and 9 times out of 10, I can reach out and hook on it with the tooth of the bucket and drag it. Sometimes I need the help of the pipelayer.
Re: Dragging Trench Boxes
Hey Rino, What size trench box is it and what size machine are you pulling it with?? On our 18ft x 6ft Wide x 8ft Deep box i usually just grab the spreader bar and pull the box forward when utilizing a 325 and then just press the box back in place at the re-inforced corners.
Vagitarian
A 8' x 16' typically we use 3' spreaders. I don't like pulling on spreaders, I have seen too many look like banana's.
Yeah, I've seen those:
our spreaders are 8" schedule 80....take quite a bit to bend them
someday, i'll be as patient as Nick. |
Trade: underground
With the box standing upright (on its cutting edges) on the ground the hoe walks up to it, reaches over its length, and grabs it by the rear spreaders. Booming up picks the whole box off the ground. The hoe can then walk up to the ditch, lower the box into a resting position and get out from under it. Our main boxes are 20 footers
Fortunately I keep my feathers numbered for...for just such an emergency. -Foghorn Leghorn |
Same here, our spreaders are diesel, the only way you are bending them is.... you aren't bending them, lol.
dirtySiD
Trade: M.U. contractor
drag um by the spreader nearest you after you dig the next set if you are in good dirt. move/carry them with your 4 leg sch 100.
put your narrow bucket on and dig them down in unstable soils from inside the walls adding an occasional push from the top.
__________________ SiD ________________ Everyone goes home, Every night. ___________________ |
| Coating Boxes.. | Al Taper | Drywall | 20 | 09-08-2007 12:50 PM |
| trench boxes | rshackleford | Excavation & Site Work | 3 | 07-08-2007 08:46 PM |
| Cover electrical boxes when spraying? | icfbunt | Painting & Finish Work | 14 | 12-16-2006 02:59 PM |
| Pricing a trench | Frame To Finish | Excavation & Site Work | 10 | 07-22-2006 11:56 PM |
| digging a trench | econoline | Electrical | 7 | 01-16-2006 05:30 PM |
