Crushed Stone Volume To Tonnage??
Old 04-12-2008, 01:08 PM   #1
Aframe's Avatar
Trade: Carpenter/GC
I'm covering a 700' sf driveway with 1/2" crushed stone approx 3 deep".
volume works out to
175 cuft (6.5 cuyd)
Does any one have a quick data sourse weight to area calculation for basic matierials crushed stone / stone dust /sand/ etc.
Thanks
Aframe is offline
Old 04-12-2008, 01:11 PM   #2
Professional Instigator
rbsremodeling's Avatar
Re: Crushed Stone Volume To Tonnage??
volume works out to
175 cuft (6.5 cuyd)
Thanks
100 pounds per cubic foot
rbsremodeling is offline
Old 04-12-2008, 01:22 PM   #3
Aframe's Avatar
Trade: Carpenter/GC
thank you sir,
Aframe is offline
Old 04-12-2008, 01:58 PM   #4
Kgmz's Avatar
That number is a good rough estimate.
Are you asking this so you know how many tons to order?
Your best bet is to ask the gravel pit what their weight per volume is, because it can vary depending on the type of rock, etc.
Here are the numbers from one of our local pits. Our area pits have a sheet you can request that gives you the numbers, and is usually included with the price sheet.
Sandy Loam 1.2 tons to cubic yard
Topsoil 1.25t
Clean Crushed 1.25
Crushed Rock/Minus 1.35
Pea Gravel 1.4
Drain Rock 1.4
Conc Agg 1.4
Oversize 1.4
Washed Sand 1.4
Mound Sand 1.4
Bank Run 1.5
Pipe Bedding 1.5
Concrete Mix 1.5
Kgmz is offline
Old 04-12-2008, 05:03 PM   #5
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
I usually figure that 1yd weighs 3,000lbs.
With that, I come up with about 10 ton.
rino1494 is offline
Old 04-12-2008, 06:33 PM   #6
mmexcavation's Avatar
Trade: Excavation
The quarry is your best bet for tonage. I did however get a little slide ruler from the vulcan quarry here and it allows you to do length, width, and depth. Also allows a density adjustment. Free and it's handy.
mmexcavation is offline
Old 04-12-2008, 10:04 PM   #7
Aframe's Avatar
Trade: Carpenter/GC
thanks all,
supplier was closed so could not get it from them, will definitly consult them when I place order.
I did the scratch the head version
80lb bag of concrete = 2/3 cu ft. ya thats just a bit more than 110lbs per cu ft.
sounds good
Aframe is offline
Old 04-17-2008, 02:31 PM   #8
WorkinDirt
pottsgroverc's Avatar
Trade: Site Work
All depends on the type of stone. Need to find the weight of stone from the individual quarry. All quarries will have different weights. And the weights may vary greatly per region.
pottsgroverc is offline
Old 04-18-2008, 11:10 PM   #9
Midnight
Blas's Avatar
Trade: Excavating, Grading, Demolition, Underground Utilities
Multiply loose cubic yard's needed by 1.4 and that will get you pretty close.
"It is what it is"
Blas is offline
How do you handle volume discounts? Mike Finley Business 89 10-24-2008 11:34 AM
Stone Archway jp33 Masonry 1 01-30-2008 10:10 PM
Stone Wall Pricing CJKarl Masonry 45 01-09-2008 08:23 PM
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 10:09 PM
