Catch Basin / Driveway Drain
Old 09-03-2007, 04:24 PM   #1
bobbyg's Avatar
Trade: Earthmoving
i have a customer who wants me to replace a catch basin drain that runs to a stream behind their house...
they have a driveway that slopes away from the street and currently the runoff collects in the catch basin and spills out of the basin and towards their garage
obviously the pipe is either clogged or crushed causing the backflow... w/ out seeing the job and from your experience do you think the catch basin will need to be replaced or can i just excavate out the old pipe and replace the pipe
i have not done a job like this but want to give it a shot...any advice would help....thanks...bg
www.granarasearthmovingservice.com
bobbyg is offline
Old 09-03-2007, 04:49 PM   #2
Captain of the Titanic
Vinny's Avatar
Trade: Asphalt Paving,Excavating, Masonry
Re: Catch Basin / Driveway Drain
Well, first look at the walls of the structure. if thier failing, which they may be, then yes you will need to replace that as well but often a new pipe can be run. On the other hand if this Catch basin is old and small you may want to replace it for your convieniece.
BTW alot of towns here have gotten real nutty on the CB and pipe to daylight thing. If you can do this job and not go down for a permit I dont see the harm. You are after all repairing an existing system not installing a new one.
Roccies Asphalt Paving
The Right Way Driveway Company
If you say you cant, your a loser. If you say you wont, your a quiter. Which one do you want to be?
Vinny is offline
Old 09-03-2007, 04:52 PM   #3
jmic's Avatar
bobby,
Has the c.b. been maintained ? (cleaned on regular basis ) Did you notice if their was a sump below the outlet in the c.b.?
What type of pipe was used ? Please don't say corrugated abs . Size ? If you need to change out the pipe and the structure is in good shape I don't see the need to change it out.
Joe
jmic is offline
Old 09-03-2007, 06:07 PM   #4
tgeb's Avatar
You really need to put your eyeballs on this and find out what the real deal is, it could be that the pipe is simply clogged with debris, could be crushed, could be the pipe is fine and the Catch Basin is fouled with debris.
It is also possible that the C/B is on public property and should be maintained by the local Government.
You have to be careful with things that dump directly into streams, you don't want the sediment control guys on your butt.
Get out there, take a look see, and post back with your findings.
www.gebcon.com
tgeb is offline
Old 09-03-2007, 10:28 PM   #5
fhdesign's Avatar
Trade: Construction, Landscaping
Like everyone says, need more information...size of cb, sump, lid/grate, pipe, etc. Could be a simple fix or it could be a nightmare, either way it's not a problem you just need to price it correctly.
fhdesign is offline
Old 09-03-2007, 10:53 PM   #6
IHateJoeCool's Avatar
Trade: Municipal Highway & Bridge
First I'd be checking with the local government to see if it's their problem, if not, and the basin or pipe needs replacement, can it even be dumped back into the stream without mounds of red tape from En Con, City hall, or village hall? With a total rip up and re-construction, they may want it hooked up to the sanitary storm system?
Anyways,
Be Safe,
JAY
RIGHT LANE CLOSED AHEAD
IHateJoeCool is offline
Old 09-04-2007, 06:04 AM   #7
dayexco's Avatar
what is a sanitary storm system?
dayexco is offline
Old 09-04-2007, 06:06 AM   #8
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
That is where you take a leak in a creek.
rino1494 is offline
Old 09-04-2007, 09:35 PM   #9
Sanitary Sewer System........
Old 09-04-2007, 10:02 PM   #10
CaliDesigns's Avatar
try and snake the Pipe. You know how many time a landscaper or sprinkler guy has messed up my drainage system! See if there is something constricking the flow, then go from there.
CaliDesigns is offline
Old 09-04-2007, 10:26 PM   #11
TMatt142's Avatar
BTW...Never ever....ever drain a storm sewer into a sanitary sewer!!! They monitor sanitary lines, thus they know the flow output from any given point. A sudden peak in flow rates and they can zero in to the work you've done.. If the CB is big enough and not too deep take a look see, or use a mirror to see if it's blocked. It's already been said, but be careful about taking this one on. EPA and watershed districts don't care too much for storm water runoff draining into natural streams...they tend to get a bit rustled over that kind of thing.
TMatt142 is offline
Old 09-05-2007, 09:29 AM   #12
MC Excavating's Avatar
Trade: Excavating, Grading, and Demolition.
Hire a plumber with a camera and a hand held locater. SEE whats going on in there and have him mark out where the clog is located. If it can be snaked then snake it. If a small section needs to be replaced then replace it.
MC Excavating is offline
The Following User Says Thank You to MC Excavating For This Useful Post:
slowforthecones (08-14-2009)
Old 08-14-2009, 10:09 PM   #13
wrightconst's Avatar
Trade: general contractor
Stick to craigslist, dont get in over your head
wrightconst is offline
Old 08-14-2009, 11:49 PM   #14
slowforthecones's Avatar
Trade: scab
Yeah send a camera line down there and see what's up before you dig. I had this happen one time with a customer, someone got really mad at him and poured a 90# bag of fixall, thinset or grout down his driveway drain with water. Sent a camera line down there about 20 feet...... needless to say I replaced his driveway gutter drain and pipes.
In a attempt to thwart future vandals or reduce the amount of blockage/damage, I installed a trap and put wire mesh on the driveway gutter drain and the pipe draining the trap, so if there is "powder" less of it goes down the drain pipes. SS wiremesh that's really fine is cheap, slows the drainage down but it's still managable.. I told the client to check your drains every week or so to see if it needs the wire mesh cleaned.
slowforthecones is offline
Condensate drain question airwick HVAC 6 07-23-2007 07:48 PM
Driveway drainage C.C.R. Landscaping 7 05-06-2007 02:27 AM
TnP drain line with company JamesNLA Plumbing 4 12-05-2006 07:28 AM
...continued...garage floor drain progress carlspackler Plumbing 0 05-27-2006 02:54 PM
bathroom basin suggestions? PipeGuy Remodeling 4 02-19-2006 03:17 PM
