Cat Hydo Hydraulic Oil Alternative - Excavation & Site Work - Contractor Talk
Old 09-24-2017, 05:16 PM   #1
mtnxtreme's Avatar
Trade: Roofing / Masonry
Rewards Points: 44
Is there any alternative to the Cat HYDO oil for hydraulic system ? I saw some Traveller brand "Premium" Trans Hydraulic Fluid at Tractor Supply but it only lists Cat T0-2 designation which is an older one, so I'm afraid to buy it. Is there any aftermarket oil that matches the HYDO spec, Cat Hydo is $ 150 for 5 gallons at the Cat dealer and I need 4 pails. !
mtnxtreme is offline
Old 09-24-2017, 05:52 PM   #2
rustyjames's Avatar
Rewards Points: 1,578
Re: Cat Hydo Hydraulic Oil Alternative
You'd might want to try that question over at the heavy equipment forum. John Deere is the same with their "TorqueGuard" or "Hyguard" or whatever.
rustyjames is online now
The Following User Says Thank You to rustyjames For This Useful Post:
mtnxtreme (09-24-2017)
Old 09-24-2017, 05:57 PM   #3
mtnxtreme's Avatar
Rewards Points: 44
OK I'll do that, I have an account there too , thanks !
Old 09-24-2017, 06:07 PM   #4
rustyjames's Avatar
Found this: http://www.imakenews.com/lubritec/e_...e003381053.cfm
Old 09-25-2017, 10:40 AM   #5
Fishindude's Avatar
Trade: Industrial
Rewards Points: 454
I've been told using off brand hydraulic oil will void the warranty on your hydraulic system. Wouldn't recommend it for a newer machine. Have to be careful when you switch attachments back and forth too, that you don't hook up something with the wrong oil in it.
Fishindude is offline
Old 09-25-2017, 07:23 PM   #6
mtnxtreme's Avatar
Rewards Points: 44
Well it's used so no worries there, but, everyone uses Cat oil at $ 150 a pop which means $ 600 to change the oil ? I can't believe there is no alternative.
Old 10-03-2017, 09:59 AM   #7
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,622
Napa has a to-4 rated oil, it's called napa to-4
jhark123 is offline
The Following User Says Thank You to jhark123 For This Useful Post:
SmallTownGuy (10-04-2017)
Old 10-04-2017, 06:24 PM   #8
Vagitarian
rino1494's Avatar
Rewards Points: 2,388
We use only Cat oil on our Cat equipment.
rino1494 is offline
Paint chipping Dpear Painting & Finish Work 8 05-28-2013 11:23 AM
Lightweight concrete alternative in a condo DanFreysinger Flooring 17 11-14-2012 10:10 AM
Wanted: Hydraulic turntable for 1991 john deere 790 dlc excavator rbob Contractor Swap 0 04-06-2012 11:30 AM
(Stone) Standard Mixer or (Ez-Grout) Hydraulic Kenny5798 Masonry 3 07-31-2011 09:01 PM
