Cat 304CR Bucket Pin Damage
Old 09-15-2017, 04:25 PM   #1
mtnxtreme's Avatar
Trade: Roofing / Masonry
Rewards Points: 44
Just picked up a 2003 304CR, the pin that attaches the bucket to stick is shot, its not so loose where it attaches to the bucket but where it attaches to the stick is very wobbly, can anyone tell me the procedure to repair this, will a new pin kit suffice or do I need to get oversize pins etc ??
Also looking to put a hydraulic thumb on, can anyone tell me the best place to get one, it has the hydraulic lines but no hook up for the cylinder to attach.
mtnxtreme is offline
Old 09-15-2017, 06:08 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,041
Re: Cat 304CR Bucket Pin Damage
Probably worn bushings. Replace both bushings and shaft, and you should be good to go.
Tinstaafl is offline
mtnxtreme (09-15-2017)
Old 09-15-2017, 06:56 PM   #3
rustyjames's Avatar
Rewards Points: 1,548
I've seen them getting really sloppy, to the point that the bushing is gone. Don't let it get that far! It's not too difficult of a job, if you have the right tools, mainly a hydraulic puller/press for the bushings.
Or, you can burn out the bushings with a torch and chill the bushings in dry ice and hammer them in. I've done it that way successfully, but the bushings were about 2.5" diameter, might not shrink enough with a smaller bushing.
rustyjames is online now
The Following User Says Thank You to rustyjames For This Useful Post:
Old 09-15-2017, 09:44 PM   #4
dayexco's Avatar
Rewards Points: 1,896
if the wear exceeds bushing diameter, you'll need to get it line bored, have machined and install oversized OD bushings, or after line bored, (this is what I would do) weld back up to factory spec, machine out to OEM bushing OD so you can use the one that was intended.
dayexco is offline
Old 09-16-2017, 06:52 AM   #5
mtnxtreme's Avatar
Rewards Points: 44
Does anyone make an oversize bushing for it, Cat or aftermarket ? I haven't looked real good at it but does the bucket have a bushing also ?
Old 09-16-2017, 07:40 AM   #6
rustyjames's Avatar
Yes, bucket should have bushings. If it's wore beyond the bushings it'll be really sloppy. I would imagine oversized bushings are available.
Old 09-16-2017, 09:12 PM   #7
dayexco's Avatar
this by far is the best thing to do, allows you to go back to OEM bushings
dayexco is offline
The Following User Says Thank You to dayexco For This Useful Post:
Rio (09-17-2017)
Old 09-17-2017, 06:33 AM   #8
mtnxtreme's Avatar
Rewards Points: 44
https://www.youtube.com/watch?v=pbulAqZ2G4M
Nice but I wonder what it costs, wouldn't it be cheaper to just bore it and put a bushing with an oversized OD ?
Old 09-17-2017, 04:32 PM   #9
Designer/Contractor
Rio's Avatar
Rewards Points: 1,796
What a slick machine!
Rio is online now
Old 09-17-2017, 04:40 PM   #10
Designer/Contractor
Rio's Avatar
This came up as the next youtube vid after the one that dayexco had up, looks interesting.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
mtnxtreme (09-18-2017)
Old 09-17-2017, 09:43 PM   #11
dayexco's Avatar
bet if you went to sam's club or costco you could find a cheaper fix yet.
guess it's just how much you depend on your machinery and if you can afford downtime.
didn't you say that machine had like 5k hrs. on it? it wasn't used, it was abused. we rolled/traded most of our excavators at 7-8k hrs....VERY seldom had to replace pins/bushings. buy good grease, and use it.
dayexco is offline
The Following 3 Users Say Thank You to dayexco For This Useful Post:
jhark123 (09-17-2017), mtnxtreme (09-18-2017), SmallTownGuy (09-18-2017)
Old 09-18-2017, 06:56 AM   #12
mtnxtreme's Avatar
Rewards Points: 44
Exactly ! It has 3200 hours got it from the original owner. Of course no one greased it, and it got loose and instead of new bushings and pin, they just kept on using it. He swears its not egg shaped and can accept a new bushing, I still have to pull the bucket to confirm, but it looks pretty darn loose to me.The weird part about it though is the machine looks well greased, unless someone got nervous after the pin got loose and went grease crazy !?
Also was thinking about my comment about not building back up to accept a stock bushing size. If you overbore and install an oversize OD bushing would it weaken it that much that it might break ?
And that expander system looks pretty cool !
Old 09-18-2017, 07:07 AM   #13
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,840
yup. that's what they did.
Likely some of those pins squealed like a pig due to lack of grease.
You know what that also means don't ya?
3200 hours without oil/filter changes.
Oh well, it is yours now...
SmallTownGuy is online now
Old 09-18-2017, 07:14 AM   #14
mtnxtreme's Avatar
Rewards Points: 44
3500 hours without oil/filter changes.
Oil and filter wise looks well maintained, he gave me records, I think it was no greasing out in the field, all the other pins seem tight thankfully, all I can say is it will get better treatment from me.
50% Damage Rule ExPro Remodeling 17 08-07-2015 03:24 PM
Help me with a photo? I need FLAT roof hail damage photo. Grumpy Roofing 52 01-08-2014 12:52 PM
TECO bucket stuck in air with busted hydraulic hose Lonewolf47 Tools & Equipment 12 09-07-2011 12:14 AM
smoke damage? have a job i need to quote ratherberacin Sandblasting 2 04-02-2010 08:02 PM
water damage and condensation bigblue General Discussion 2 01-10-2009 12:11 PM
