Trade: land developer
Buying Used Finish Crawler Dozers
I have an 2004 John Deere 550 H Lt in my sights and the moldboard just behind the outer cutting edge is bent. The moldboard is bent in about 1.5 inches. The outer cutting edge does not appear to be bent.
Is this common on used dozers? Is it best to repair or replace the moldbold and who is best to make this decision. If repaired is this a repair that an authorized John Deere shop should be making? Thanks for your comments. |
Vagitarian
Re: Buying Used Finish Crawler Dozers
WTF were they doing with it, prying on stumps or rock ??? Are you sure that the acutal moldboard is bent or is it just some metal support behind the moldboard. Seems to me that if the moldboard was bent, then the cutting edge would not bolt on too good. Check to see if the cutting edge is welded on or is actually bolted to the moldboard.
Either way, it is a easy fix if you know someone that is a good welder.
| Sticky finish...Boy could I use some advice | Uuber_Framer | Flooring | 11 | 10-26-2007 04:41 PM |
| Stripping old deck finish | joedonuts | Painting & Finish Work | 26 | 06-09-2007 11:34 PM |
| glazing over stained finish | ChuckEA | Painting & Finish Work | 5 | 06-23-2006 09:21 PM |
| Can You Help Identify This Finish? | Richie-C | Painting & Finish Work | 10 | 06-07-2006 09:34 PM |
| metal railing finish failed problem? | a68cudas | Painting & Finish Work | 9 | 06-06-2006 03:37 AM |
