Bobcat 442 Mini Ex
Old 06-08-2009, 12:28 AM   #1
Dig with BIG TOYS
digdeep516's Avatar
Trade: Landscape, Masonry, Site Prep... the grunt work
Bobcat 442 Mini Ex
Hey i was wondering what your guys thoughts were on the 442 bobcat... im looking for something to pair with a t320 for digging footings and just general trenching on other jobs... think it will keep up. Its either that or the 435 but to me it looks too small almost, i still wanna get into backyards with the thing but i dont want to be able to beat it with a shovel.
digdeep516 is offline
Old 06-08-2009, 09:14 AM   #2
JDavis21835's Avatar
Trade: Excavation
Re: Bobcat 442 Mini Ex
A 435 is certainly a capable machine. I have had one twice for my own use. First time was digging a drain line, and setting a catch basin. The catch basin was around 4,200lbs. The second time was two for one job. Used the machine to grade a polebarn for concrete. After that, I used it to remove a heafty maple stump. Roughly 4ft diamater. Left 6 feet of the trunk so I had something to push and pull on. Cut around the stump, at about a 8ft diameter, then I pulled the stump over, cut as close to the root base with a saw, got rid of as much of the dirt from the root ball, and drug the rest out of the hole. Good solid little machine, only thing I dont care for is the high speed track system they use.
JDavis21835 is offline
Old 06-08-2009, 05:11 PM   #3
tgeb's Avatar
I have a 435 and like it very much, for me the 442 would simply be too large to get into many of the places I need to work.
Last week I dug out enough tree stumps to overfill a 30 yard dumpster, all the trees where flush cut at the ground. A couple were too big and heavy to pick up and I had to shove them in the door of the can.
I spent less than a day and a half to dig them out and a few hours loading the dumpster.
I like the "fastrack" drive system.
You should try one out before you buy it to be sure it will suite your needs.
Another option for you is the new models they have out. The E80 is heavier than the 442 but has minimal tail swing.
www.gebcon.com
tgeb is offline
Old 06-08-2009, 05:58 PM   #4
Dig with BIG TOYS
digdeep516's Avatar
yeah i saw the E80 but i thought the 442 has a zts or zhs right... thats more of a creature comfort for my operators but if the 435 can rip stumps like that than i could see it as having a pair. Whats the reach if you wouldnt mind me asking because im starting to get into foundation digging so i wants to make sure i can have the length and reach available
Old 06-08-2009, 10:04 PM   #5
tgeb's Avatar
Reach is about 18'.
You are right about the 442 being zero tail swing, I thought it was conventional type.
All the specs are on Bobcat's site.
http://bobcat.com/excavators/models
By the way......welcome to the site.
www.gebcon.com
tgeb is offline
Old 06-08-2009, 10:20 PM   #6
BobsLandscaping's Avatar
Trade: Landscaping
I rented a 442 twice. Nice machine. Plenty of power and capability. Only thing I didn't like was the noise. It seemed awfully loud for that class of a machine.
BobsLandscaping is offline
Old 06-09-2009, 03:59 PM   #7
Dig with BIG TOYS
digdeep516's Avatar
thanks tom... the name is Justin by the way... yeah i guess im just gonna have to demo them and find out for myself. You know how that 435 would compare to the 337... its the bigest bobcat excavator ive run and i really liked that
Old 06-09-2009, 06:31 PM   #8
tgeb's Avatar
For the most part I would say they are equal.
http://www.bobcat.com/excavators/com...ls/compare_all
www.gebcon.com
tgeb is offline
Old 06-11-2009, 05:04 PM   #9
Dig with BIG TOYS
digdeep516's Avatar
yeah im making the drive out to bobcat on saturday to do some demoing... only problem is that now there so far away from me because they moved... they used to be right in westburry now there in maspeth like 3 hours away from me. Guess its kind of a good thing though because other wise id be broke and have every single attachment bobcat owns =]
Mini Van for work?? mnjconstruction Vehicles 16 03-02-2009 01:53 AM
using a bobcat to fill a dump truck 72chevy4x4 Excavation & Site Work 7 01-12-2009 10:19 AM
2007 yz 250 - trade for old bobcat EPD Contractor Swap 9 01-11-2009 03:32 PM
Mini Excavator Question magnet Excavation & Site Work 2 08-29-2008 08:15 PM
JCB V.S. Bobcat, or CAT Mini Excavator oasis100 Excavation & Site Work 10 06-29-2006 08:53 PM
