Bobcat 328 Hydraulic Problems
Old 12-29-2008, 08:47 AM   #1
anglianplant's Avatar
Trade: plant sales
As the title states my Bobcat 328 has some issues with the hydraulics, looking for some advice if possible?
Symptoms:
Very little to no power to left track
Very slow and weak movement of dipper arm and bucket rams
Blade is very slow and again very weak, wont lift the machine. The strange thing is when you lift the arm with the servo control on and the safety is activated and you then operate the blade it works as it should and can lift the machine!!??
Any ideas?
Regards
Joe
anglianplant is offline
Old 12-29-2008, 09:07 AM   #2
tgeb's Avatar
Re: Bobcat 328 Hydraulic Problems
Welcome to the site, Joe.
The first thing I would do is change the hydraulic filters. There could be more than one, my 435 has 3.
How old is this machine? How many hours?
It could be a solenoid issue, or a pressure relief system problem. From what you have so far described I am thinking solenoid problem, you might just start checking the connections to each component on the valve bank.
Let us know what you find out.
www.gebcon.com
tgeb is offline
Old 12-30-2008, 04:50 AM   #3
Trade: plant sales
Hi Tom
Thanks for the advice, I will check as you suggest and let you know my findings.
The machine is a 1999 and has done 3200 hours. I have changed only one filter so will hunt the others down and replace too.
Thanks
Joe
Roofing Credit problems roofpro350 Roofing 10 10-06-2008 04:43 AM
Ice Problems on a roof J-Peffer Roofing 4 10-01-2008 11:12 AM
Hydraulic Thumb Question? denick Excavation & Site Work 4 08-29-2008 08:12 PM
super corner problems?? softtop95ta Windows, Siding and Doors 22 02-12-2008 09:38 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
