Trade: plant hire
Bobcat 320 1/2 Ton Mini Digger
does anyone know where to locate the fast track sensor on the above machine?
Re: Bobcat 320 1/2 Ton Mini Digger
I'm not sure I understand the question.
The fast track system probably has solenoids that activate the high speed, but may or may not have "sensors". What exactly is the problem? |
Trade: plant hire
probably just a difference in terms, i suppose the solenoids could be what i am looking for, would you happen to know where to locate them?
Trade: new construction and remodeling
this is probably a dumb question, but when you see someone grading/leveling with a blade and the 2 laser targets on sticks they are still manually adjusting thier blade height, right? thanks
#5 | |
Re: Bobcat 320 1/2 Ton Mini DiggerQuote:
What exactly is the issue you have? |
#6 | |
There are some systems that are "indicate" only are are used as a guide for the operator and all machine functions are performed by the operator. |
Trade: plant hire
machine tracks but doesnt fast track, the button works but isnt connecting with the fast track solenoid/sensor? i want to locate them and check why it wont connect.
Your best bet would be to contact the dealer.
They will be able to point you in the right direction. That circuit could be fused, have you checked the fuse panel? |
| bobcat 442 mini ex | digdeep516 | Excavation & Site Work | 8 | 06-11-2009 05:04 PM |
| Rigid 5gal Mini Wheel Barrow | Big Baby | Tools & Equipment | 1 | 03-08-2009 04:49 PM |
| Mini Van for work?? | mnjconstruction | Vehicles | 16 | 03-02-2009 01:53 AM |
| Mini Excavator Question | magnet | Excavation & Site Work | 2 | 08-29-2008 08:15 PM |
| JCB V.S. Bobcat, or CAT Mini Excavator | oasis100 | Excavation & Site Work | 10 | 06-29-2006 08:53 PM |
