Trade: Owner
Basic Construction Staking
Hi All, Spent quite a while yesterday staking out a site where we are about to begin a new house. While we aren't excavators, I would like to have a basic idea of how to square up the stakes??? It's not as easy as you'd think! Is there somewhere on line that I can read up on the basic geometry behind staking?? Thanks!
#2 | |
Re: Basic Construction StakingQuote:
Two tape, the diagonals of a rectangle or square are equal when the corners are 90º. Then there is ...a²+b²=c², or "the sum of the squares of the two right sides is equal to the square of the hypotenuse."
Youngster
Trade: Builder / Consultant / Designer
I'll go ahead and explain one of the easier ways to do it that is essentially just an ellaboration of neolitics statement. Most house footprints are essentially just a rectangle with a bunch of juts and bump-outs. Ignore the bump-outs. Determine from your plans what size the core rectangle is. (In my case, once I got rid of the bump-outs, the core rectangle was 33' long on the side of the house, and 70' long on the front of the house.)
Then follow the steps below. I've provided my measurements on my last build to help you understand.
Youngster
The method I explained above would tell you how to locate and square up a building on the lot. If all you are trying to do is determine the lot boundaries on a square lot, the same method applies, but you just have to substitute the lot dimensions in for the building dimensions.
Trade: general contractor
I do it similiar to the above description but extend my stakes out past the corners several feet on each side so they don't get dug out, the you can stretch stings and plumb down and reset them in the basement after it has been dug
Trade: site work
For us we use our total station or GPS and layout where the building is going then set off sets somewhere around 30-50 feet away depending on what is out of the work area. then we use the off sets as we are digging in order to put the corners back into the hole.
One of the KEY things that have been left out of these responses is that when you pull measurements with a tape you also MUST be level with the other point you are checking from.
If not you will never get your building square. You also need to work with people that understand what it is you are doing and why. I once arrived at a site and the lead carpenter was laying out with a guy that was typically doing design and drawings. I noticed that the guy was measuring to a level held plumb and marking the layout onto the footing. But when I spoke up and asked why he, (the new guy), was holding the tape on one side of the level and marking the footing on the opposite side, you should have seen the lead carpenter's face, they had to go back through the whole layout and correct the mistakes. Had I not dropped in when I did, the building would have been out of square a couple inches. ![]() John1066, has probably the best method, but you probably need $75K -$150K to get his setup, then you have to learn how to use it..... You can layout a simple foundation pretty quickly with tapes and stakes if you do the math first. It's not that hard, but you must remember to hold the tapes level. |
Trade: site work
No your right the Gps works great but for simple stuff its easy to scale of the plans and pull tapes in to where you have to go. but i still think your better to offset everything you do so that you don't have to redo everything you did. if you put your building corner in offset it 30' to the side
to offset right tho it takes two stakes 10 feet apart in a straight line with the original point. this gives you that same location again just by pulling a tape. it works great for all applications. and the other trick with that is if you pulling 50 and 60 feet always pull from the 60 then run the tape right by 50 and you will be all set. |
Trade: Home Remodeling
I pay my surveyor to do it.
He has a handheld HP device that interfaces with his survey equipment. We give him the foundation plan in autocad format, he loads up the plot plan on the HP handheld, loads the foundation plan and the app he uses lines the house up. He then tweaks it and starts placing stakes. The old way we did it was a²+b²=c². |
Trade: Owner
Don't know what I'd do without this forum! My employer has actually said "if I have to show you, I might as well do it myself" -- NOT super helpful!
Thanks for all your quick posts! |
#11 | |
#12 | |
An appropriate response from a good employer would have been, "Come on we'll do this one together, ask as many questions as you need to, you will do the next one, and it better be right." |
Trade: home builder carpenter Central Alabama
first off get yourself a construction calculator. I have one by calculated industries called Construction Master IV. It is one of my favorite tools, it does everything in 5 seconds it took me a year of geometry to learn. Itll do stairs, area of circles, metric, feet AND or inches, and a bunch of other stuff. Pick it up at home depot for $50. comes in a rubber protective case too.
As far as laying out we do it like others said using a 100' tape and flags. First pull the tape to show where the front wall and front door will be and make sure everybody is happy with that. Then do your squaring from that line like everybody else said. One thing we do differnt than alot do is we do not build the batter boards till after the concrete pour. There just in the way. We square it up with flags, lay a string on the ground from flag to flag and mark it with lime and pick up the sting. We have our excavator with a 24" bucket dig with 3/4 of bucket to inside of line and 1/4 out side. Gives plenty of room to square up using a tape and level like someone said. |
Trade: Excavation Contractor
Here is an easier method that I use. Determine what you are squaring off to. i.e neighboring building, road, property line, etc. and set your initial side off of that with the appropriate setback. Once your first side is set and staked, pick a stake to pivot off of. Figure out your diaganol dimension using the Pythagorean as mentioned earlier(convert decimal to inches by multiply decimal portion by 12). Pull the tape to the eyeballed corner, set your paint can at the determined diagonal and spray as you make a reasonable arc. Go to the opposite stake, pull whatever dimension is on the plans(I typically do a 6' overdig per dimension since it never fails that someone will want to move something "just a smidge"
P.S. this is of course assuming a level area. In the case of hillsides, then there are a whole lot of other tricks that you often make up as you go. Last edited by cexcavation; 07-17-2008 at 01:19 AM. |
P.S. this is of course assuming a level area. In the case of hillsides, then there are a whole lot of other tricks that you often make up as you go.[/QUOTE]
You got that right. We once built a house on a hillside that droped about 8' from front to back in about 30' run (not too bad but a first for us at the time). Without fancy gps equipment we had to go ahead and build batter boards 10' tall to hold the strings. We first measured holding the tape up best we could to get a whereabouts for the batters. When we strung the strings and pulled the tape low and behold it was square right of the batt ![]() We spent the next hour measuring an remeasuring in disbelief but it was still right. |
#16 | |
Youngster
If you want to save a little time and expense of using batter boards on hillsides (although this is quite effective, I've never used them), the Pythagorean theorem pulls through again. Since you know how far out you are in height, and your hillside is usually
#18 |
Commercial construction
Trade: Commercial construction
I usually just do it by eye. Never had a problem yet.
#19 |
Re: Basic Construction Staking |
#20 |
Actually, that's quite possible if you've traveled much at all.
I would love to see some images of the 11' batter boards. Last edited by mikesewell; 07-18-2008 at 12:21 PM. |
| I want to get in Construction and am looking for advice | chompchomp12 | Business | 21 | 12-17-2009 10:39 PM |
| CCD - and construction image | Mike Finley | General Discussion | 6 | 08-31-2007 09:37 AM |
| 22 Undeniable Construction Truths | Ed the Roofer | General Discussion | 0 | 01-26-2007 06:00 PM |
| associate degree in construction management | soldiermccoy | Construction | 6 | 06-30-2006 01:01 PM |
