Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Excavation & Site Work
Old 06-24-2009, 09:03 PM   #1
BuildCrew
Trade: Fencing, Decks, Barns, Flatwork
anyone have a picture of a garage footer dig?
I am trying to figure out an economical and smart way to get my footers installed for an upcoming project.
the details:
-28x40 structure.
-garage is actually a daylight basement (1 side) with 3-sides covered earth
-house will be above garage/basement
-I will dig down 6' to basement floor, then install 10" deep footer forms for the 3 sides above grade.
-I need help with the 4th side where the garage doors will be....
The side where the garage doors will be obviously need to be below the frost line, and that said (about 36")... I can only think to dig a 22" wide trench (the width of the footers) x 36" deep and fill her up with concrete.... I priced doing just the bottom 10" in concrete (no forms on that side) and then finishing the height with block, and it really does not save any money.
Any thoughts? Should I just make a very thick buried stem wall on that side up to grade (to match the other 3-sides finished footer heights?
If you have done a garage/basement like this before, you may have some pics of what you ended up doing?
thanks!
bnentrup is offline   Reply With Quote
Old 06-24-2009, 10:13 PM   #2
tgeb's Avatar
Usually we run the strip footing on through and let the mason run block across the openings, then slab on top of wall.
Sometimes we will omit the footing along the openings and when slab time comes we will form the front of the slab and then dig out by hand the required depth for frost protection.
I would imagine the second scenario would be less expensive in the long haul, but I personally think the first method is better.
www.gebcon.com
tgeb is offline   Reply With Quote
Old 06-25-2009, 05:33 AM   #3
joasis's Avatar
You don't have any guidence from the building code guys?
Everytime i read these kind of posts, I thank God I am in an area where we call the frost line 12 inches, or for all intents and purposes, we don't have a frost line. It is always about engineering here and proving it to the inspector.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
405 314 5802
joasis is online now   Reply With Quote
Old 06-25-2009, 08:07 AM   #4
OGStilts's Avatar
OK I reread the OP 4 times and now think I understand what you are doing...
I would still do what ever my plans said to do because that what the inspectors are going to be looking for.
OGStilts is offline   Reply With Quote
Old 06-25-2009, 10:45 AM   #5
Slow Roller
Trade: Fan of Bodger
^^This is your answer^^^
the permit office will require structural drawings, so it doesn't matter what you want to do or not do. you are required to build in accordance to your structural drawings
Crock is offline   Reply With Quote
The Following User Says Thank You to Crock For This Useful Post:
dayexco (06-25-2009)
Old 06-25-2009, 10:58 AM   #6
I just read all your previous posts and I see they are just about all about this project.
Do you even have plans, as I see you haven't decided how you are going to build it or have changed how you are going to build it?
If you had plans and engineering, you would know how the foundation is built, how the floor joists are attached, etc. etc. All previous questions you have asked, and you asked this same question a month ago.
Kgmz is offline   Reply With Quote
Old 06-25-2009, 11:14 AM   #7
Trade: general contractor
What type of material is the garage slab in? If it's NFS just insulate and pour on grade with a standard thickened edge to support a two story.
mics_54 is offline   Reply With Quote
Old 06-25-2009, 08:37 PM   #8
joasis's Avatar
You are a contractor? Flatwork?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
405 314 5802
Pole Barn Garage mrmike Carpentry 26 10-28-2009 07:29 PM
Footer for Subdivision Sign fakie99 Masonry 3 02-24-2009 09:39 AM
Vapour barrier between garage and living area?? big builder Insulation 18 12-23-2008 02:25 PM
residential footer dutchlegacy General Discussion 20 07-23-2008 07:44 AM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 08:48 PM
