DRIFTWOOD
Trade: GEN CONTR.
Air Block On Fuel ?
Running backhoe on gravel road with pot holes, pretty bouncy. Dies like outa fuel. Has 3/4 tank full. Add 5 gals of diesal next morn starts fine!
I'm thinking the bouncing grabbed some air ,and blocked the fuel. Any ideas??? Thank's Drift |
Re: Air Block On Fuel ?
Drift
You either have to go slower or take paved roads.
I would be suspect of the fuel filters as opposed to "catching air" through the pickup tube in the fuel tank.
Or possibly a slightly loose fitting on the fuel line that allowed some air in during your rough ride. ![]() I also would recommend a little less speed on these back roads.
Drift,
It can be anywhere from the tank on up. It could be something in the tank. The pick up line in the tank, A line that might have a crack, Fuel filter gasket, If you have a glass fuel bowl (especially the 2 piece ones they are notorious for this on some machines). If something happens (in your case maybe a real bouncy trip) allows air in or blocks a line under suction it can be fine after it sits for a while whether you added the fuel or not. It might not show itself until the circumstances are right again. Maybe Elast will stop by and have some info for you.
Nick "Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein |
DRIFTWOOD
Trade: GEN CONTR.
This is a good time to have My friend service it. And yes I do need to slow down on the rough roads. With that heavy hoe on the back things can get interesting FAST
| Cinder Block walls, block filler and a leak...question | SeanATL | Painting & Finish Work | 9 | 03-09-2009 04:33 PM |
| Block Walls | DaHammer | Masonry | 29 | 03-06-2009 07:11 PM |
| Does fireplace opening in block wall opening need support? | Square-One | Masonry | 6 | 11-22-2008 02:31 AM |
| Glass Block Transition | Paul_NJ | Ceramic & Stone Tile | 0 | 03-15-2007 08:14 AM |
| Does fireplace opening in block wall opening need support? | Square-One | Construction | 1 | 02-28-2006 01:59 AM |
