4-Way Dozer Blade Functions - Page 2 - Excavation & Site Work - Contractor Talk
Old 03-11-2017, 07:57 AM   #21
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,872
Re: 4-Way Dozer Blade Functions
Originally Posted by Seven-Delta-FortyOne View Post
I've looked at the 6-way, but I'm going to be using the machine for logging and stump pulling, so I need something a little heavier duty. I'm looking at either a D6 or D7. If it tilts, and I can re-cut the ditches on the roads at the ranch as well, that'd be a bonus.
I can do a passible lob grading a road with a skid steer , so a dozer will be even better.
Thanks for the assistance.
Delta
Get a 6 way with a telescopic push frame.
Inner10 is online now
Old 03-11-2017, 08:26 AM   #22
tgeb's Avatar
Rewards Points: 1,592
A six way on a D-6 or D-7 will be plenty tough enough for logging and stump removal.
www.gebcon.com
tgeb is offline
Old 03-11-2017, 12:43 PM   #23
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 812
Originally Posted by Peter_C View Post
Can you easily rent a grader for roads? Water bars are important to the road system. Road maintenance is a constant battle against water damage, at least in wet conditions, which is where the trees grow best.
Are you planning on skidding logs with the dozer? (If so that is going to be slow going vs a wheeled skidder that can move far more rapidly for faster turns.) You can walk the trees out to a deck like location with the feller buncher.
Why pull the stump? Blow that sucker up! More fun
HUG THE TREE before you cut it
I might buy an old grader. I've seen them for 5 to 8 grand for an older one. It would work fine for a couple times a year.
I'll use the winch for pulling logs up. It's more of a selective cutting, along with some of the trees coming up some pretty steep slopes. There is also a fair amount of general grading that will be done, for a variety of reasons.
I'll be pulling stumps in areas where future construction will take place.
Where in NorCal are you? I'm up in Humboldt.
Do they make them? I've never seen a 6-way on anything bigger than a D4.
Delta
Old 03-11-2017, 01:13 PM   #24
Trade: Builder/GC
Rewards Points: 812
Well, if the Mods are OK with it, I'm gonna kind of turn this into a general Dozer question thread.
I have a lot of operating hours under my belt, but mostly with excavator, backhoe, loader, tele handler type stuff. I haven't run ton of road-building or logging type machinery.
So I'm getting conflicting information on the elevated sprocket/Hi-Drive system. Some say that it'll throw the track on steep slopes while turning in reverse and some say the Hi-Drive increases traction. Every tracked skid-steer I've ever used had a Hi-Drive, and I've done some pretty fancy maneuvering with them. A skid-steer ain't a D7, though.
So what are some opinions on Hi-Drive vs. conventional?
Delta
Old 03-11-2017, 01:35 PM   #25
tgeb's Avatar
Delta
I don't know, I haven't been around a big dozer in quite a few years.
www.gebcon.com
tgeb is offline
Old 03-11-2017, 01:56 PM   #26
Trade: Builder/GC
Rewards Points: 812
Well, I was wrong. I just found one on MachineryTrader. 2000 something D7 with a 6-way. I think in the later models, you can get them.
Prolly out of my price range, though.
I'll probably end up going for an older D6, with a 4-way, and an even older grader for the roads.
Delta
Old 03-11-2017, 02:55 PM   #27
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 2,368
Makes more sense to get a 6 way then buying a broken down old grader, that we will call the money pit. I would recommend renting one if needed. It will take a decade to recoup the costs otherwise.
So you will be hand cutting trees on steep slopes? Risky business! I would assume some of those trees are massive. There is a lot to know about logging. Please be careful, my uncle was killed logging while skidding logs cross slope in the winter. My cousin wound up with over 400 stitches from a kick back. Winch cables are extremely dangerous. The list of friends and family injured or killed logging is extensive.
As of last week we finally got a line logger in to log some of our steeper sections where a feller buncher can't go. We had a fire rage thru in 2015, fortunately only taking out 600 acres of trees, but there wasn't a line logger available, so we wrote them off as a loss. Blued pine is worth nothing, and dead timber is bad for bark beetle infestations; we loose
Do you know Forestry? I have been learning for most of my adult life and still don't know enough. We employ a Forester to help us run the logging outfit, mark trees, deal with permitting, road maintenance, and all the other hassles. We are a Certified Tree Farm, so eco logging aka selective is the right way to do it. Leave the biggest trees for propagation, taking only what is good for the land. None of this horrible clear cutting crap!
Fortunately my sister is an invasive species specialist, and we have been working to keep the land semi clear of some nasty plants, and insects. The Oregon Department of Forestry has been using our land as a basis for the last 25 years, and they were happy to certify us as a tree farm. Right now "certified" doesn't mean much but hopefully in the future the sustainable practice pays off.
6 way! Those water bars in your area are going to be VERY important. Lots of rain. Carry a shovel and while touring be prepared to stop and hand dig them if needed. Water bars will keep a road from getting taken out.
I haven't done trees of your size, but we did take out a cherry orchard. We found hitting them with the blade a few times usually worked, and if not we turned around and used the ripper on one side, then went back to using the blade to push them out.
Our home is in the North Bay, but our farm is in Eastern Oregon. Our Forester is headed to SoCal via 101, so I told him to visit "Tall Trees", as there is nothing else like it. He went to school there in Humbolt, but never visited that grove, and to me who lives near some of the large redwood groves they just doesn't compare, not even Lady Bird grove. Of course Lost Coast Brewery is on the tour list
Peter_C is offline
Old 03-11-2017, 07:05 PM   #28
Inner10's Avatar
Delta
All of the 6 way blades with telescopic push frames seem to be in the past 25 years.
Seven-Delta-FortyOne (03-11-2017)
Old 03-11-2017, 07:28 PM   #29
Trade: Builder/GC
Rewards Points: 812
That's what I'm finding. And that they are kinda out of my price range.
Peter_C, good info there, thanks.
I have several personal friends, and a few acquaintances killed in logging accidents. Our project is a quite a bit smaller, as the ranch was logged about 40 years ago, and then basically left. It needs a ton of remedial work, and most of the trees are smaller, like 36" diameter average. Still, caution must be exercised.
I'm not a forester, I'll just be the equipment operator on the project. And as an EMT, the unofficial safety supervisor.
Delta
Peter_C (03-11-2017)
Old 03-11-2017, 08:39 PM   #30
Peter_C's Avatar
Eco logging can allow a 10-20 year cut rotation. Although the trees won't be 36" If you got redwoods that is a whole other ballgame.
I am not familiar with timber markets in Cali, but carefully watch the timber futures. Profits are thin, and holding the logs on deck for a few months can make a big difference. Also pay attention to government funded programs for things like thinning. The gov will also assist with putting a stewardship plan together, which can include a grazing plan, water plan, etc. These days letting livestock wander around water sources is frowned upon.
Peter_C is offline
Old 03-11-2017, 10:42 PM   #31
SouthonBeach's Avatar
Rewards Points: 1,027
Delta
My understanding of the hi-drive is it was made to keep the final drive train out of the muck and crap.
Will it throw a track doing fancy maneuvering, that's probably going to depend on the condition of the rollers and rails more then anything.
Just look Cat is really the only one with hi-drive dozers.
Hi-drives weight more then their comparable counterparts, so yes you'll have increased traction.
You'll also have more cost rebuilding the undercarriage on a Hi-drive.
SouthonBeach is offline
The Following User Says Thank You to SouthonBeach For This Useful Post:
Seven-Delta-FortyOne (03-12-2017)
Old 03-13-2017, 01:34 PM   #32
Trade: Builder/GC
Rewards Points: 812
Well, I posted this the other day, but I see that it didn't show up.
The logging I'm doing is very small scale, as logging operations go. All the timber will be milled on site, and used for timber-frame Ag buildings, on the ranch.
I would love to get a later model D7, with a 6-way, that was also beefy enough to pull stumps, but those are starting to get out of my price range.
I'll be pulling stumps in areas where construction will take place. There is a lot of remedial pasture rehabilitation, and general cleanup work around here.
Delta
Makita LS1016L blade wobble after 8 months NINZAN STUDIO Tools & Equipment 55 08-06-2014 04:54 PM
Lenox Recip. Saw Blade JR Shepstone Tools & Equipment 30 06-16-2013 06:25 PM
Warner- "The BEAST!!!!! has been found!!....... PrestigeR&D Tools & Equipment 247 12-15-2012 08:53 AM
Computerized saw blade sharpening.... PrestigeR&D Tools & Equipment 9 09-06-2012 04:56 PM
Best Utility Knife Journeyman T Tools & Equipment 48 02-20-2008 08:54 PM
