Stains On Stucco
Old 06-30-2006, 05:26 PM   #1
Alkyd's Avatar
Trade: painter
Rewards Points: 25
Stains On Stucco
I need to remove some stains on stucco. These two stains, about two feet in diameter, are at ground level. They appear to be light rust stains. Can you guys recommend a cleaner? The home owner said he has tried muratic acid and TSP? Thanks Robert
Alkyd is offline
Old 06-30-2006, 05:30 PM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Rewards Points: 7,510
Re: Stains On Stucco
Robert, I moved your post to its own thread so it will get noticed quicker.
ProWallGuy is offline
Old 06-30-2006, 11:42 PM   #3
Where's the Grease
Michigan Exhaust's Avatar
Trade: Michigan Restaurant Vent a Hood Cleaning Company
Rewards Points: 25
We have use oxalic Acid to remove rust many of times. You may have to do the whole thing to make it even out. Don't want a bright spot with no rust. Oxalic is also known as wood bleach. Use safety precautions when using this one also. It gets in your skin and destroys the mans child making parts.
Michigan Exhaust Cleaning
Your First Step in Restaurant Duct Fire Prevention
http://www.michiganhoodcleaning.com
Dave Ott 800-861-6475
Michigan Exhaust is offline
Old 07-04-2006, 10:13 PM   #4
Guardi Pro's Avatar
Trade: Painting / Decorative Concrete
Rewards Points: 75
Try a product called Magik rust stain remover. We use this stuff alot and it works well.
Guardi Pro is offline
Old 07-18-2006, 06:59 PM   #5
SgtBaldy's Avatar
Rewards Points: 75
Coca Cola
Tampa Painters
SgtBaldy is offline
Old 02-01-2008, 12:09 PM   #6
contractor
tom connelly's Avatar
Trade: power washing - new construction and restoration cleaning
Rewards Points: 75
Oxalic is extremely toxic, and is dangerous not only to the user, but also to the environment. Try to avoid it if possible. Saferestore from EaCo Chem works very well at removing rust stains.
Gutter Clean & Power Wash
Hickory NC
tom connelly is offline
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 11:22 AM
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
Some questions about painting outside stucco?? Zeebo Painting & Finish Work 10 09-20-2006 08:09 AM
Rust stains on stucco locofoco Construction 3 07-31-2006 10:27 PM
new skim coat over old stucco 415moto Construction 6 07-12-2006 08:28 PM
