Replacement Pump For Pressure Washer
Old 06-25-2007, 05:22 PM   #1
T bone's Avatar
Trade: Builder
One of you pro's gave me a site to get pumps and replacement parts for pressure washers a couple of months ago and I can't locate it via search. Also I can't get the dang pump off the motor. I removed all the bolts I can find and it will rotate around on the shaft now but I can't get it off. Are they usually just a press fit on the motor shaft, or do they have a clip or key of some sort? This is a small delta washer with Honda 10hp engine, 3500 psi. Pump is that Italian name I can't think of here in my office. I'm tempted to beat on it, but don't want to ruin the motor or flanges.
T bone is offline
Old 07-02-2007, 03:37 PM   #2
boman47k's Avatar
Re: Replacement Pump For Pressure Washer
Might google karcher power washer and get a diagram. I recently bought one of these at a yard sale and found diagram for it. They also show other washers.
boman47k is offline
Old 07-02-2007, 03:52 PM   #3
boman47k's Avatar
That site didn't seem to have Delta on it. Sorry. I did have a site that showed diagrams for just about anything before I changed servers. I will check and see if my son still has it if I can't find it.
boman47k is offline
Old 07-02-2007, 07:07 PM   #4
tgeb's Avatar
Check out Water Cannon. That's were I get my stuff from.
http://watercannon.com/c-17-pumps.aspx
The pump is held by a set screw, you have to look close to find it. Don't smash it up!!
Call those guys they can help you through this, the pump I bought from them has be going for 6 years now.
Mine was an Italian pump also.
www.gebcon.com
tgeb is offline
Old 07-03-2007, 01:51 PM   #5
carolinaprowash's Avatar
Trade: Exterior Surface Specialists
You could probably contact Delco Cleaning Systems of Fort Worth
www.dcs1.com
Celeste
Carolina ProWash
Graham, NC 27253
336-270-4598 Office
336-516-6139 Roger 336-516-6356 Celeste
carolinaprowash is offline
Old 08-01-2008, 12:56 PM   #6
contractor
tom connelly's Avatar
Trade: power washing - new construction and restoration cleaning
www.edidistributors.com
They are a big distributor they sell most pumps including the italian pumps General and Annovi Reverberi (AR). They are very helpful, knowledgable, and reliable, they will beat any price you find from another distributor, as long as they are a reputable company.
EDI Distributors:
1-800-433-2033
tom connelly is offline
Replacement windows Bjd Windows, Siding and Doors 21 05-11-2010 08:37 AM
4 Sale: 1/2 HP Wayne Porta Pump Terrence Pressure Washing 0 04-18-2007 10:43 PM
Replacement Boilers rej@cpintenet.c HVAC 4 01-05-2007 09:58 AM
Well Pump Depth Question... thepawnshop Plumbing 9 08-13-2006 09:01 PM
What Pump to Use? dblommel Painting & Finish Work 0 03-05-2006 12:15 PM
