Pressure Washing Over Trex Deck
Old 08-10-2008, 08:12 PM   #1
wallyofthenorth's Avatar
Trade: painter
I have a log home to p.wash soon,I use a bleach mix, my question is will there be any problems with fading/discolor on this type of decking,the deck is new,and I plan on wetting down the deck first
wallyofthenorth is offline
Old 08-10-2008, 10:36 PM   #2
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Re: Pressure Washing Over Trex Deck
Simple answer: most likely yes.
I know there's better than bleach, but I'm not the pro on that part, yet.
Maybe tarp the deck, or offer a discount for doing the deck & house?
~Matt
BreyerConstruct is offline
Old 08-11-2008, 02:08 PM   #3
contractor
tom connelly's Avatar
Trade: power washing - new construction and restoration cleaning
Bleach is often used in cleaning of composite decking; however, there may be some fading of colors that will result.
Yes, there are better methods than bleach.
Prewet the deck before you apply your mix to the house, then quickly rinse after spraying chemicals onto the house. If your chemical application is a lengthy one, you may want to stop to rinse any overspray from decking surface.
Basically, under most normal circumstances, don't let it hit the decking dry, or don't let it dwell on the surface and you should be fine, always do a follow up rinse.
You may want to mention cleaning the deck at a discounted price as part of a total package.
Gutter Clean & Power Wash
Hickory NC
tom connelly is offline
Pressure washing 2300 sf concrete pitterpat Pressure Washing 13 09-28-2010 08:16 PM
Pressure Washing New Residential Homes SunSet Pressure Washing 12 11-10-2008 10:32 AM
What size pressure washer and tip do I clean a deck with? jimb317 Painting & Finish Work 11 07-02-2007 01:43 AM
pressure washing a composite deck corky Pressure Washing 2 01-31-2007 12:03 AM
Spiral staircase for Trex deck Woodcrafter74 Landscaping 2 11-21-2005 11:21 AM
