Pressure Washer, Which One?
Old 01-05-2007, 10:48 AM   #1
Dirtguy's Avatar
Trade: Sitework
Hey guys, I figure you have all had experience with different brands of washers and I am looking for some help choosing one. I am a Site Contractor and am looking for a washer to clean our heavy equipment (dozers, loaders, scrapers, etc...). I am assuming something with a little more gpm would be better suited for this applicaiton, but I don't know you guys tell me. Also, I would use the machine periodically to clean prime oil off of concrete from our paving operation. I would assume heat would be the best way to achieve that, so a heater unit would probably be required. And lastly, the unit needs to be self contained since a water source is not always available.
Dirtguy is offline
Old 01-05-2007, 11:46 AM   #2
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Re: Pressure Washer, Which One?
The compromise most guys choose would be a 5.6 gpm hot water skid. The flow rate and time being used without an incoming supply will determine the size reserve tank you need.. minimum would be about 250 to give you 35-40 mins of spray time. Look for a 18-24 horse Honda with a General pump. Parts are most readily available for this combination. I prefer to buy local so I can get service but many guys buy Pressure-Pro machines (no affiliation) over the internet. Cost for this machine will be from $4300 for a PP to $8000 for a Landa.
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Replacement pump for pressure washer T bone Pressure Washing 5 08-01-2008 12:56 PM
What features/specs to look for in a pressure washer? steve-in-kville Painting & Finish Work 11 06-03-2008 02:17 AM
TSP & pressure washer Teetorbilt Painting & Finish Work 25 04-28-2008 05:28 PM
What size pressure washer and tip do I clean a deck with? jimb317 Painting & Finish Work 11 07-02-2007 01:43 AM
pressure washer Traditions Painting & Finish Work 10 05-06-2007 11:54 AM
