Need Advise From The Pro's
Old 06-07-2007, 11:01 PM   #1
KellyPainting's Avatar
Trade: Painting Contractor
Painter here,
Wash allot, but mostly houses. Got a gas station to bid.
My question is the surface where the cars pull up to fill up, they want hot water.. (i'm a cold water guy) can I use cold with chemicals? or must I use hot? And if so... what chemical should I use?
Thanks in advance!
P.S Anyone in the mass area I can sub it out to, if need be?
KellyPainting is offline
Old 06-10-2007, 11:04 PM   #2
Re: Need Advise From The Pro's
Thanks, you guys have been very helpful.
Old 06-10-2007, 11:09 PM   #3
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
LOL, sorry Kelly.. I didn't see this one.
Pass on this job. Not only do you need hot water but you need reclaim equipment. The fine for violating the EPA's clean water act is like 10 g's and possible jail time for a first offense. It applies to washing anything, anywhere but is much more enforced with gas stations. This is a federal law.
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 06-11-2007, 08:47 PM   #4
thanx bro!
Old 08-20-2007, 11:55 PM   #5
LCO
the grass man's Avatar
Trade: Landscaping
Send a message via Yahoo to the grass man
We don't do any gas stations. Reclaiming is required and we don't use chemicals and we dont reclaim yet, we only use heat. Well, we may use some Simple Green every once and a while but heat really does the trick most of the time. Simple Green is biodegradable.
The Grass Man, LLC
Property Management
404-626-4976
the grass man is offline
Self employed guy needs some advice from the Pros to keep things straight... Luny Landscaping 14 05-27-2007 12:38 PM
Need advise on getting work... bluesman General Discussion 1 01-15-2007 11:40 PM
New painter in need of some advise Cramerica80 Painting & Finish Work 14 10-14-2006 09:52 AM
I need some advise frim the pros Unregistered Roofing 19 06-15-2004 04:20 AM
getting some advise from the pros Unregistered Roofing 2 12-16-2003 06:30 PM
