Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Pressure Washing
Old 04-10-2008, 08:07 PM   #1
Trade: Dry Ice Blasting
My new PW'r
Here's what I added to my business this week, as mentioned in another thread I added a PW to assist in Graffiti removal. I'll probably use it for other work as well, I'm noticing once people know you have a piece of equipment they start giving you work... I've added a hose reel as well - sick of picking up hose all the time...lol
  • Honda 13 HP GX Series OHV engine with low oil shut down
  • CAT Pump
  • 4000psi - 4GPM
  • 50ft Hose
  • Triplex pump with ceramic plungers
  • Forged brass manifold with variable pressure
  • Maximum pump operating temperature of 70°C / 160°F
  • Chemical injector with soap metering valve
  • Thermal relief valve
  • Powder coated frame with removable handle
  • 13 inch pneumatic wheels
  • 36 inch gun and wand assembly
  • Non-marking high pressure hose
  • Nozzle orifice size - 3.5
  • 4 Quick coupled nozzles:15° (yellow), 25° (green), 40° (white) and 50° (black soap tip)
  • Pump Warranty: 5 Year Limited (Excluding Wear Items)
  • Engine Warranty: 2 Years
company is called MCS Pressure Washers - www.mcspressurewashers.com
CO2Solutions is online now   Reply With Quote
Old 04-14-2008, 12:28 PM   #2
alright, picked it up today...just playing around with it today before I start my graffiti removal testing.
Question for you guys...the unloader valve, I should be able to adjust by hand??? or not? currently I can't by hand.
thx.
mike
Old 04-14-2008, 12:37 PM   #3
Handle It!
MALCO.New.York's Avatar
I think I like that. I like it A Lawt!
Can not go wrong with that Honda 13 GX nor the CAT pump!!!
You should be able to write your name in concrete OR cut yer toes off!!! Careful now!!!! Or does it not have a pin nozzle? (Red)
My biggest question is the gun/wand construction. All metal or plastic/metal.
Ultimate Wisdom---------
http://www.youtube.com/watch?v=_k1Ug...ture=rec-HM-r2
MALCO.New.York is offline   Reply With Quote
Old 04-14-2008, 01:12 PM   #4
PRO
Trade: CGC Concrete
Not too bad for $1400. Looks like it will last a while.
Blackhammer is offline   Reply With Quote
Old 04-14-2008, 02:09 PM   #5
Thanks, lot of fun so far...love having toys that 'blast' 'things' at high pressures...just going to add a new sandblaster next week to my toys (Dry Ice Blaster and Pressure washer). I guess the nice thing is I'm still thinking of these items as fun...sure it's tough, messy work but I still enjoy blasting.
Yeah, the gun is a plastic/metal combo - the trigger column is plastic (or a type of molded plastic).
Yes, it was $1349 CAD...list price was approximately $1875. Overall, not a bad price. I have a hose reel as well attached - it was thrown in the deal.
Old 04-18-2008, 11:07 PM   #6
Trade: Fire Suppression Equipment Sales & Service
Which Cat pump? Is the wand the adjustable pressure?
fireguy is online now   Reply With Quote
Old 04-19-2008, 07:53 PM   #7
Trade: Industrial coatings and painting
Are the CAT pumps any better than the General or AR pumps?
Casey
alpinecrick is offline   Reply With Quote
Old 04-19-2008, 09:59 PM   #8
Its the CAT 66DX40G1I series pump. No, not an adjustable pressure wand...
Old 04-20-2008, 12:22 AM   #9
Handle It!
As far as "adjustable pressure wand".........I have never seen a wand that did not respond accordingly to how hard one squeezes the "trigger". If that is what you mean. Other than that, I know not about "adjustable pressure wand". And I have managed a couple-a car washes in Phoenix/Atlanta/Florida. That is the REAL P/W!
Old 05-14-2008, 07:23 PM   #10
alright, here's a question for the tech guys here.
Will running my pressure washer with little amount of water pressure hurt the pump (or pressure washer in general)??? I ran it today for a short while (15-20 mins) and there was no water pressure and it was sputtering quite a bit...frustrated me...lol.
Old 05-23-2008, 08:45 PM   #11
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Yes, this can cause substantial damage to the pump. Similar to running an engine without oil. If your line ever chatters when you are washing you are not getting enough supply to keep up with the pump. You should have a resevoir or reserve tank on your machine with the unloader plumbed to bypass into it.
PressurePros is offline   Reply With Quote
Old 07-11-2008, 11:40 AM   #12
contractor
Trade: power washing - new construction and restoration cleaning
Never run your pressure washer without water in the pump, squeeze the trigger till water comes out first, then crank it up. It's kinda like running an engine without oil. It can really mess things up. Never run your pressure washer for extended periods of time without releasing pressure, as the pressure build up will damage the pump as well. Also make sure you over winter your machines properly.
Cat is a good but expensive pump, not only for the pump itself but also for the parts. Often 3x's more expensive for parts and kits. Perhaps better than General and AR but i don't think its always worth it. We typically use General. Legacy makes an excellent pump as well, its a Landa in disguise.
tom connelly is offline   Reply With Quote
