Restoration Crazy
Mold On Hardie
I've got about 1000 sf of Hardie sideing for my house. The material is primed lap siding. I started putting it on the house last year untill the winter weather showed up. I covered the material and walked away for the season. When I uncovered it a few days ago it was dry but it had mold on it.
What have you guys used that is mild but kills and removes mold. My first thought was bleach/water mix but I'm worried the bleach might screw up the primer coat. I'll need to clean both sides and let it dry before I install it. Hope you can help, Thanks.
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
Re: Mold On Hardie
I have always used bleach, but I see your concern. I think TSP is an option. Check out the labels and it shoudl tell you if it will.
Cal You hired WHO
Restoration Crazy
Re: Mold On Hardie
Thanks Cal. I'll look into that
Trade: Dry Ice Blasting
Re: Mold On Hardie
Hey Jason,
I'd stay away from bleach, try a product called Concrobium - you can get it at Home Depot. It kills mold and won't damage the siding, as well you don't have to worry about the surrounding area. |
Handle It!
Re: Mold On Hardie
I have always used a mild solution of bleach. It works best. Period. Bleach has little damaging effects on non-organic compounds.
The next best thing is Dimethyl Benzyl Ammonium Chloride. The real question is WHY is there mold and what must be done to prevent the return. The US Forest Service suggests: Powdered household detergent 1/3 cup Household liquid bleach 1 quart Trisodium phosphate 2/3 cup Water 3 quarts
Something to One may be Nothing to another! Ultimate Wisdom--------- http://www.youtube.com/watch?v=OW-cnizLDEE Last edited by MALCO.New.York; 03-21-2008 at 11:33 PM. |
#6 | |
Re: Mold On HardieQuote:
Siding Windows Doors
Trade: Exteriors
Re: Mold On Hardie
We use comercial non detergent bleach 3/4 cup per gallon and a weed sprayer and spray, then let sit for a few minutes and then wipe. This will kill the mold and mildew without hurting the siding. If you have a bad stain you may want to use KLIZ primer on it.
Trade: Exteriors
Re: Mold On Hardie
Trade: Exteriors
Re: Mold On Hardie
Trade: Exteriors
Re: Mold On Hardie
Can you imagine all the warranty jobs in about ten years when some of the cement board planks begin to have real mold issues on the back of the panels and into the walls.There is no way to avoid mold unless the entire plank is sealed so moisture and dust cant get behind the siding. When the warranty lawsuits start everyone including the manufacturer will be pointing a finger at the siding installers even if its an obvious roof leak.
SEALERGUY
Re: Mold On Hardie
Mild bleach solution will work, scrub with soft to medium brush, rinse(it wont hurt the primer at all), Once you get the siding up, if you can afford it use sherwin williams duration latex house paint, it's around 40/gallon, but you wont be repainting anytime soon. The mold grew from sitting under that tarp for a while, wet, with just enough light for it to grow. It will not grow like that once you get it in the air where it can breath.
DECK-TECHS-MICHIGAN-DECK RESTORATION-BRICK PAVER RESTORATION- |
Handle It!
Re: Mold On Hardie
My experience is this: Bleach and water. NO SCRUB. Soak (20 minutes). Hose. Repeat. MAGIC!
Mold WILL proliferate if it is not COMPLETELY cured. After cleaning, Sunlight is a wonderful fixative! Put bleach on a hard wood floor and watch stuff rise out of it! I LOVE BLEACH. It WILL be very important in the not so distant future. WATCH! And for those Eco-Minded persons. Bleach breaks down into a simple salt and water/hydrogen gas. IT WILL NOT DAMAGE MOTHER EARTH.
Something to One may be Nothing to another! Ultimate Wisdom--------- http://www.youtube.com/watch?v=OW-cnizLDEE Last edited by MALCO.New.York; 04-16-2008 at 11:51 PM. |
#13 | |
President
Trade: Installing windows, siding, roofing, doors, patio rooms, gutters and shutters.
Trade: Pressure Washing & Roof Cleaning
Re: Mold On Hardie
Use a bleach solution with a mild soap. Apply let dwell, and rinse away.
Lance Powell Clay County Pressure Cleaning, Inc Pressure Washing Florida Roof Cleaning Jacksonville |
| Concrete Dust on Prefinished Hardie | Cecil | General Discussion | 3 | 01-06-2008 10:37 PM |
| Possible Black Mold between 1st and 2nd floor | TurnkeyConst | Remodeling | 10 | 04-25-2007 11:37 PM |
| New Construction Showing Mold... | thepawnshop | Construction | 13 | 10-20-2006 07:43 PM |
| When you find mold?? | theworx | General Discussion | 2 | 03-05-2006 03:15 PM |
