Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Pressure Washing
Old 05-02-2007, 07:48 AM   #1
Trade: HANDYMAN
Mineral Stains On Brick
WHAT IS THE EASIEST WAY TO GET RID OF HARD WATER STAINS FROM LAWN SPRINKLERS I KNOW THAT THERE IS SOME CHEMICAL THAT I CAN USE IN MY POWER WASHER.
BAREBACK is offline   Reply With Quote
Old 05-02-2007, 09:37 AM   #2
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Acid. But don't run it through your pump. Use very low pressure to rinse. And pre-wet the brick so you don't burn it.
PressurePros is offline   Reply With Quote
Old 01-30-2008, 11:17 AM   #3
contractor
Trade: power washing - new construction and restoration cleaning
www.eacochem.com
they can set you straight real fast. And make it very easy.
It mostly depends on how bad the stains are. Different degrees may mean different measures.
Gutter Clean & Power Wash
Hickory, NC
tom connelly is offline   Reply With Quote
Old 01-30-2008, 03:14 PM   #4
Trade: Decks
Yeh that is like removing rust. depending on how bad it is there are different acids you can use. Just be careful with the stronger ones because you can etch the bricks if they are not used properly.
zukkoor is offline   Reply With Quote
Old 03-14-2008, 07:53 AM   #5
SEALERGUY
sealerguy's Avatar
Trade: DECK RESTORATION-BRICK PAVER RESTORATION-
Send a message via AIM to sealerguy
HOME-D usually carries a product called rust aid, it works fairly well on mineral deposits most of the time, it's oxalic acid so do a test area real quick, I keep a bottle in my truck at all times and sell rust removal at jobs when needed, it usually melts right off instantly.
sealerguy is offline   Reply With Quote
Thin Brick, VS Regular Brick Project53 Construction 26 03-11-2010 03:13 PM
Braking metal for a brick exterior? Luke's Dad Windows, Siding and Doors 8 01-07-2007 06:59 AM
wire behind brick hurricaneflyer Electrical 7 11-13-2006 08:03 PM
Low (12" or so) brick garden wall questions bindersbee Masonry 8 04-27-2006 07:31 PM
red brick has developed a white coating wbsbadboy Masonry 4 02-28-2006 09:33 PM
