Log Homes?
Old 09-08-2008, 04:00 PM   #1
woodchuck2
woodchuck2's Avatar
Log Homes?
What are you fella's using for pressure when cleaning a Log Home? I am using 2500psi and i am keeping the tip away as not to damage the pine, problem is i am still shooting water inside the home through the logs. I would expect seepage but the water is actually shooting 2'-10' inside. I have had to roll up some of the throw rugs and move furniture so nothing gets too damaged. Obviously i had some water damage from the water until i found it at the end of the day. I am thinking of using an electric washer now with only 100-1600 psi to see if i can prevent more water intrusion. Thankfully i contacted the owner who is also a general contractor and he is very understanding. Thanks for your time.
woodchuck2 is offline
Old 09-10-2008, 01:22 PM   #2
contractor
tom connelly's Avatar
Trade: power washing - new construction and restoration cleaning
Re: Log Homes?
Use the lowest pressure you can get by with, 100-200 psi or so. You may want to brush the home before you rinse it to create a softer rinse.
I've heard of one guy shooting chems 10' across a room and ruining a baby grand piano. So yeah, it happens, be careful.
Give Russell a call from Extreme Solutions
1-636-288-8512
www.woodrichbrand.com
Gutter Clean & Power Wash
Hickory NC
tom connelly is offline
Old 09-17-2008, 05:55 AM   #3
woodchuck2
woodchuck2's Avatar
Re: Log Homes?
Well i had to leave one wall due to belongings on the porch, the owner stated he would move everything himself so i let him. He arrived and moved his items and decided to just clean the wall with brushes and a garden hose. He too had alot of water intrusion through the wall with only 30-35psi so now we beleive there is a problem with how the home was constructed. He paid me right up in full and asked if i would stain the home, cut 8-10 tree's, move some large stones, level part of his yard, add onto the culvert next to the road, widen his driveway and chip up 4 huge piles of brush. Apparently my honesty to the problem and the extra steps to clean up and avoid more problems was worth it.
Developer bankrupt but we have homes there fishorski Construction 8 08-26-2008 10:06 PM
modular homes newguy07 General Discussion 35 06-29-2008 10:16 PM
Poured Foundations +- phanley Masonry 22 07-22-2007 01:17 AM
Performance System Built Homes and Energy Efficiency Hello john haddad Introductions 0 11-11-2006 11:09 AM
Custom Homes - Building Superintendent Needed: Durham, NC CWPritchard Help Wanted or Looking For Work 0 04-11-2006 11:40 AM
