KEW Pressure Washer Question
Old 08-22-2007, 08:45 PM   #1
painterman's Avatar
Trade: Historic Restorations
I have a old (1985) Kew "hobby" pressure washer that works great for what I do. I had to replace the hose unit complete. The problem is that the new hose will not fit onto the pump. I think it might be a metric thread.Can I purchase an adaptor to make the new hose fit.
painterman is offline
Old 04-23-2008, 01:44 PM   #2
Gotlummber's Avatar
Trade: General Building
Send a message via AIM to Gotlummber
Re: KEW Pressure Washer Question
I have the same unit and need to know how you regulate the pressure on it?
Gotlummber is offline
Old 04-28-2008, 10:13 AM   #3
painterman's Avatar
Not sure what you mean regulate the pressure: the tip on mine turns to make the pattern change.
Old 04-28-2008, 10:16 AM   #4
painterman's Avatar
Ok I have been able to attach the new hose and wand to the machine. The new hose is 25 feet 5/16 the old hose is 25 feet 1/4 inch. With the new hose the machine will bulid pressure but pulsates all time ,back to the old hose all is good ,whats up with that.
Old 04-30-2008, 10:59 AM   #5
boman47k's Avatar
Lot of difference in the diameter of the hoses in terms of volume. I may be wrong, but I think I have seen Teetor post something on this. Seems like it goes something like a quarter increase in pipe equals more than a quarter increase in volume of liquid being delivered through the hose or pipe, so I guess the pump/engine has to work harder.
I bet someone in the plumbing section could answer this.
boman47k is offline
Replacement pump for pressure washer T bone Pressure Washing 5 08-01-2008 12:56 PM
What features/specs to look for in a pressure washer? steve-in-kville Painting & Finish Work 11 06-03-2008 02:17 AM
TSP & pressure washer Teetorbilt Painting & Finish Work 25 04-28-2008 05:28 PM
What size pressure washer and tip do I clean a deck with? jimb317 Painting & Finish Work 11 07-02-2007 01:43 AM
pressure washer Traditions Painting & Finish Work 10 05-06-2007 11:54 AM
