How Do The Roofing Manufacturers Say To Clean Roofing? Like This=
Old 08-28-2011, 10:43 AM   #1
5282jt's Avatar
Trade: Roof etc cleaning
This Is The Roofing Manufacturers Method Below: Check it yourself. It says not to pressure wash!
You have probably heard all the new fad "GO GREEN" "Biofoam" "Bio Degradable" "Eco-Friendly" roof cleaning pitches that have cropped up recently. Or the $$ making Roof-A-Side type programs, that keep guys walking on your roof once or twice a year to maintain clean appearances?
They try to convince unknowing homeowners that chlorine bleach should not be used on roofing to clean with.
The reason is, they know that chlorine is the industry standard and what the manufacturers allow roofs to be cleaned with under warranty.
However, there are many, many real professionals cleaning roofs properly with chlorine-per manufacturer instructions.
So, these new start up companies try to get work by telling lies about chlorine use. But you won't see them posting a roofing manufacturer that suggests their chemicals or pressure washing, because none do.
It's their way to fool you into thinking you are helping save the environment!
What is more damaging to the environment? - chlorine, which is everywhere and turns back into plain salt when it dries?
Or roofing shingles in dump sites, because they only lasted a 1/2 life, due to improper cleaning methods? DON'T BE FOOLED!
Here are the facts from The Roofing Manufacturers Themselves.
It's your warranty, you can listen to the green salesman and pressure washing guys, who can blast the discolorations [ along with your roofs granules etc ] off from your roof, or to those who make the roofing and honor warranties or void them. { Incidentaly, I am not against pressure cleaning! It is perfect for all exterior cleaning other than roofs. I have been a pressure washing contractor since 1978 - I just know better than to pressure clean fragile roofing ! }
Here you go! I could easily supply more proof, but this is pretty obvious, I'd say.
From GAF Roofing Manufacturers about black algae removal:
http://www.gaf.com/Documents/Algae_S...-43-808-v3.pdf
Below is a partial "cut and paste" excerpt from GAF on how to clean a roof:
"If a new roof is not an option, GAF recommends cleaning the roof with a special mixture. That mixture is:
4 gallons of water, 1 gallon of bleach and 1 cup of TSP"
"What NOT To Do! Do not power wash the shingles to clean the shingles. Some roof cleaning companies offer this service.
However, it is not recommended."
From ARMA roofing manufacturers Association-how to clean roofing.
http://www.asphaltroofing.org/pdf/tb_217.pdf
Below is a partial excerpt cut and pasted below from ARMA:
Algae discolorations to remove from roofing surfaces, applying a solution of
chlorine bleach, trisodium phosphate, and water. Solutions for these ingredients depend on the amount of discoloration. Solutions range to one cup TSP and 2.5 gallons each of bleach and water.
First, gently disperse this solution on the roofing surface. Avoid scrubbing the surface, as this friction may loosen and remove granules.
Caution!
High pressure washing systems for algae removal should not be used.
Owens Corning Roofing manufacturers says the same thing:
"USE CHLORINE and TSP" "DO NOT USE A PRESSURE WASHER"
Owens Corning info in link below.
http://webapps.easy2.com/cm2/flash/g...ge_id=36077811
So, those who manufacture your roofing and warranty your roofing are the folks to listen to!
Not those who pressure wash roofs, or try to sell you a so called "Green" Eco-Friendly" chemical.
We clean roofs ONLY by the roofing manufacturers methods, so your warranty will not be voided!
WE ARE RCIA CERTIFIED ROOF CLEANERS: ROOF CLEANING INSTITUTE OF AMERICA. LINK BELOW:
http://roof-cleaning-institute.activ...1055740&page=1
With years of experience , it became clear to me that while pressure washing roofs made them look clean, damage was occurring on the roofs. Pressure cleaning machines can only be turned down so far and still accomplish roof cleaning and any amount of pressure, even as low a setting as 300 psi { 3000 to 4000 psi is what most pressure cleaning contractors use } will still remove around 15-20% of the granules that make up the color and protection of your shingle roof per cleaning.
Ugly black algae, left in place on the roof, eats around those granules and the rain removes them. Still eventually destroying the roof and spoiling it's appearance and resale value. With tile roofs, pressure removes the glazing many tile roofs come with. Pressure also blows pieces of cement that hold the ridge-caps in place off into space! If your tile roof is painted, pressure will blow portions of paint off all over the roof, leaving it in need of an expensive paint job!
How do the roofing manufacturers say to clean roofing? Like this=-17-golfview-roof-001.jpg   How do the roofing manufacturers say to clean roofing? Like this=-17-golfview-roof-005.jpg   How do the roofing manufacturers say to clean roofing? Like this=-example-roof-47-par-view-rd-oct-1-2010-2-.jpg   How do the roofing manufacturers say to clean roofing? Like this=-before-cleaning_401-johnson-lane-venice-commercial-roof_-building_walks.jpg   How do the roofing manufacturers say to clean roofing? Like this=-after-cleaning___venice-roof-401-johnson-ln-022-4-.jpg
How do the roofing manufacturers say to clean roofing? Like this=-2011-shingled-roof-job.jpg
Last edited by loneframer; 08-28-2011 at 02:45 PM. Reason: removed self promotional text
5282jt is offline
The Following User Says Thank You to 5282jt For This Useful Post:
WildWill (12-14-2011)
Old 08-28-2011, 01:58 PM   #2
Thomas J Marino, Inc
thomasjmarino's Avatar
Trade: Custom Home Builder/General Contractor
Re: How Do The Roofing Manufacturers Say To Clean Roofing? Like This=
As Butthead would say, "words,words,words"
thomasjmarino is offline
The Following 2 Users Say Thank You to thomasjmarino For This Useful Post:
5282jt (08-28-2011), Dirtywhiteboy (08-28-2011)
Old 08-28-2011, 03:00 PM   #3
5282jt's Avatar
Interesting who you choose to quote!
Clearly, you recognize the validity of what was said and have no reply.
As with Beevis and Butthead, what you said makes no sense?
Words, word, words of the roofing manufacturers.
Who do you listen to with other expensive things you own, that are under warranty? Isn't it usually the manufacturer?
Actually, I thought this was the first thing I have ever read about roof cleaning, that was finally more than just "opinions" and "words"
It's the product maker!
Like I said, we pressure clean too, but we listen to the manufacturer, when it comes to other peoples property.
How do the roofing manufacturers say to clean roofing? Like this=-boca-grande-pressure-wash-job.jpg   How do the roofing manufacturers say to clean roofing? Like this=-during-cleaning_venice-roof-401-johnson-ln-032-12-.jpg   How do the roofing manufacturers say to clean roofing? Like this=-ls-job-004.jpg
5282jt is offline
Old 12-14-2011, 12:30 PM   #4
Tampa
Roof Cleaning's Avatar
Trade: Roof Cleaning
Chuck, you did a beautiful roof cleaning for that Chiropractor.
I hope he gave your tired old arse a couple of free sessions for that beautiful tile roof cleaning job ?
I needed a break, and business has been good for us this week in the Tampa area. My Son and his helper are out cleaning roofs today, and I got to take a much needed week off
Apple Non Pressure Roof Cleaning Tampa
Roof Cleaning is offline
Old 01-08-2012, 09:09 PM   #5
4 seasons's Avatar
Trade: Contractor/ Carpenter
Thank you OP for your post, spread the knowledge!
4 seasons is offline
The Following User Says Thank You to 4 seasons For This Useful Post:
5282jt (08-12-2012)
Beacon Roofing Supply Announces Acquisition of Western Canada-based Enercon Products Grumpy Roofing 1 06-01-2011 09:58 AM
GC and construction clean up bluehawaii07 Commercial Construction 5 01-21-2010 06:45 PM
Manufacturers vs. Retail warranty Bill Henderson Windows, Siding and Doors 6 10-14-2008 09:01 AM
Owens corning a solid strip of tar nolo Roofing 26 01-29-2008 12:25 AM
