Exterior House Cleaning Solution
Old 02-20-2007, 10:02 PM   #1
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
Rewards Points: 526
Hello guys and gals,
What is a good solution/mixture to spray on a house that has alqae. I will be using a pump sprayer. The alqae is not too bad, just unsightly. The alqae is on the roof and sides. Should I spray and let it be or rinse afterwards? Thanks, Norm
Norrrrrrrrrrrrm is offline
Old 02-20-2007, 10:18 PM   #2
Sharp Improvements
Rewards Points: 526
Re: Exterior House Cleaning Solution
I forgot to mention, there are dogs on the property so a biodegradble or pet friendly solution would be nice.
Old 02-20-2007, 11:17 PM   #3
HUDSONVALLEYEXT's Avatar
Trade: EXTERIORS
Rewards Points: 250
Clorox Outdoor works the best its around 6 bucks at lowes or depot. Spray on and wash off in a few mins. Use of a power washer would also help
HUDSONVALLEYEXT is offline
Old 05-03-2010, 11:04 AM   #4
Home_Contractor's Avatar
Trade: Gutter and Roofing Contractor
Thanks for the tip, I was looking for something like this too.
Home_Contractor is offline
Old 05-03-2010, 08:18 PM   #5
oldfrt's Avatar
Rewards Points: 94
I just did one side of a an older(12 Year)
aluminum sided cape.
The local Hardware had several cleaners available so I grabbed the one
that was the mildest for shrubs and figured if I had to do it twice,
it was worth the effort,since there was a bed of myrtle around this area.
Pre-wetting any vegetation and a later rinse will reduce/eliminate any damage by the cleaner
I sprayed it on with the soaking nozzle of the pressure washer,and
let it set 10 minutes.
I also tested the rinsing pressure,and found that any pressure
removed the color from the siding,which had peeled off already
in other areas of the house.
I ended up using a brush to loosen the algae/mold and rinsed with
a hose.
Just be careful with a power washer.
oldfrt is offline
Old 05-06-2010, 07:51 AM   #6
General Contractor
Giftcard's Avatar
Rewards Points: 250
A little bleach and Dawn dish soap. Wet plants before, during and after application.
Giftcard is offline
Old 07-12-2010, 09:11 AM   #7
SparkleCleaning's Avatar
Trade: Owner house cleaning service
Yes, excellent advice!
SparkleCleaning is offline
Old 07-12-2010, 10:40 AM   #8
The Roof Cleaners LLC
Roof Cleaner PA's Avatar
Trade: Roof Cleaning, Pressure Washing
In a 2 gallon pump sprayer, just add 1/2 gallon of store bought bleach and 1 1/2 gallons of water. Add about 4 ounces of ultra concentrated dish soap (don't use antibacterial) mix well and apply to the siding. Start at the bottom and work your way to the top. Let the mix sit on the siding until you see the algae turning brown or melting away. Spray the siding again to keep it wet if necessary. Most times you will not have to use a brush, but the brush will just make it faster. Rinse with a garden hose starting at the top and working your way down.
There are many ways to clean siding. This way is simple and will work for someone without much experience with a pressure washer.
Brian
Roof Cleaner PA is offline
Old 07-25-2010, 10:16 PM   #9
House Painters Reading PA
4thGeneration's Avatar
Rewards Points: 250
I am not sure about the antibacterial, but please do not mix Ultra Dawn with bleach/SH because you will have such a headache from the gas and fumes it will put out. It will be toxic and could be deadly...
Bleach/SH Dawn original formula are compatible though.
Colonial Power Washing and Painting by Sutton provides
House Painting Services in Reading PA
for all Interior and Exterior Projects
484-334-1311
4thGeneration is offline
The Following User Says Thank You to 4thGeneration For This Useful Post:
Dave Mac (06-19-2011)
Old 07-25-2010, 10:22 PM   #10
Paintlady's Avatar
Trade: paint contractor
Rewards Points: 75
Pittsburgh's Mildew Check. mix as directed, and than rinse. Works great! Bleach and dish soap work well too.
Paintlady is offline
Old 08-02-2010, 03:58 AM   #11
Rewards Points: 250
One problem with the mildew check from Pittsburgh Paints is that it leaves behind a protective shield. what that translates to is that if you paint behind that stuff your paint could have problems down the road because they will only be applied to the coatings and not the substrate.
Tom vogel from ACRproducts has some good chemicals.
484-334-1311
Old 08-02-2010, 07:01 AM   #12
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,900
That's a 33% bleach solution. I use max 10% bleach, 5% simple green, rest water.
4 th Gen - Any comment on the bleach % or simple green ?
We Fix Houses is offline
Old 08-02-2010, 08:12 AM   #13
Rewards Points: 250
SH/Bleach is fine if its handles by a pro. Across the board most people who Pressure Wash Houses like me use a 12.5% SH mix.
*Secret*
484-334-1311
Old 08-12-2010, 07:10 PM   #14
"Mold Man"
StevenJ's Avatar
Trade: Mold Remediation & Restoration
Rewards Points: 25
Store brand distilled white vinegar, 25% solution with water. $2.50 a gallon and is safe and effective with a pressure washer, not to mention very inexpensive.
StevenJ is offline
Old 08-12-2010, 10:44 PM   #15
Paintlady's Avatar
Rewards Points: 75
We have used the Mildew Check without a problem, the "protective Shield" aids the mold, alge etc. not growing back. We have top coated and had NO problem. Espcially in shaded, moist areas that mold and alge grow back quickly using just a bleach only solution.
Old 09-07-2010, 02:06 AM   #16
www.Scottwash.com
Scottwash's Avatar
Trade: Pressure Washing
Rewards Points: 25
oxy clean get form a chemcial store your plants will love it.
Integrity Pressure Cleaning Plus
Pressure Washing / Roof Cleaning / Soft Washing / Condos / Homes
Palm Coast Florida 32164
www.Scottwash.com
Scottwash is offline
Old 10-29-2010, 12:42 PM   #17
rebeccataylor's Avatar
Trade: Rebecca Taylor
Just washing with water will do the job as long as it is with a pressure washer.
rebeccataylor is offline
Old 10-29-2010, 12:51 PM   #18
Rewards Points: 250
water alone will only remove the visual algae, but it will not kill the algae. Please dont tell me your washing houses with water only?
484-334-1311
Old 10-29-2010, 02:54 PM   #19
I was trying to keep from making my explanation too technical, but I guess I need to clarify it for you.
1/2 gallon of bleach in a 2 gallon sprayer is actually 25% not 33%. 4 half gallons = 2 total gallons. The mixed solution is 25% of a 6% active ingredient (store bought bleach has a 6% sodium hypochlorite active ingredient). The actual active ingredient of the mix I gave you will be 1.5% sodium hypochlorite that you are spraying on the siding. 1.5% to 2.0% hitting the wall is really what you are striving for when you are doing house washing. It is a good balance between cleaning and not damaging plants and surroundings.
If you are using "max 10% bleach" in a pump up sprayer, that means you are putting 1/5 of a gallon of bleach in a 2 gallon sprayer. That mix wont clean siding with any efficiency. 10% solution using store bought bleach (6% sodium hypochlorite) will give you a .6% active ingredient hitting the siding. That is not strong enough to effectively oxidize algae.
I don't personally use a pump up sprayer for much other than touch ups or demonstrations. I don't use store bought bleach. I down stream 12.5% sodium hypochlorite and simple cherry through an Allison Super Suds Sucker Injector using high volume, low pressure tips on my wand. With that being said, the math is the math. It doesn't matter what your application method is, you want to get to a certain active indredient of sodium hypochlorite hitting your siding. Doing the proper math will give you a way to clean siding using an x-jet, downstream injector, pump up sprayer or dedicated tank and pump system.
As far as the dish soap goes, you want to make sure that the dish soap doesn't have ammonia in it. Ammonia reacts negatively with sodium hypochlorite to produce poisonous fumes. I use myristamine oxide instead of dish soap. It is SH stable and a little goes a long way.
Sorry for being so technical. I was just trying to give a simple solution to his pump up sprayer application method.
Brian
The Following 2 Users Say Thank You to Roof Cleaner PA For This Useful Post:
4thGeneration (10-29-2010), flatroofing (03-03-2011)
Old 11-11-2010, 02:27 PM   #20
bugsy714's Avatar
Trade: General
fyi bleach varies consiterably with brand; from 1.5% to 6% concentration
Walmart sells a generic bleach that is $2.50 for 1.5 gallons 6%
bugsy714 is offline
Drain cleaning Moonray Plumbing 14 12-25-2009 11:41 PM
Power Washing Solution? welovepainting Painting & Finish Work 0 08-14-2007 04:21 PM
drain cleaning the_turd_man Plumbing 13 02-07-2007 05:26 PM
