Trade: Power Washing
Couple Questions From The New Guy.
Hey everybody, just found this forum.
I have a couple of questions, since I am looking into starting my Pressure Washing Business, since there are none in my area. 1) I have yet to figure out ... How do you clean 2 story buildings? If you use a ladder, don't you get water under the vinyl siding (which is bad)? 2) Where is a good place to get insurance from? 3) Engine bays ... what's a good way to clean those? Use a degreaser from the auto parts store, spray it down, let it soak, then rinse off with low pressure (or lowest high pressure), while covering up the alternator, fuse box, and distributor? Leave engine running? I might have many more questions to go, but I would appreciate yalls input
#2 | |
Trade: Exterior Surface Specialists
Re: Couple Questions From The New Guy.Quote:
Celeste
contractor
Trade: power washing - new construction and restoration cleaning
How to clean 2 story houses without ladders?
x-jet and downstream, also get to know your chemical line very well. Let the detergents do the work so you dont have to. They should be your best workers. If you get them all workin together you can kiss your ladders good bye. A light weight long lance will also make a huge difference. Make sure you use low pressure, high pressure will also force water under your vinyl. You wont learn it all overnight thats for sure. Gutter Clean & Power Wash Hickory NC Last edited by tom connelly; 01-28-2008 at 03:06 PM. |
#4 | |
Al Smith
| Couple basic tiling questions | fast pasquale | Flooring | 10 | 06-26-2007 02:40 AM |
| switched receptacle- a couple of questions | ChuckEA | Electrical | 19 | 02-15-2007 09:20 AM |
| A couple of $ questions | dkillianjr | Business | 25 | 12-13-2006 10:27 PM |
| Couple of trailer questions for the pros | Mike Finley | Vehicles | 38 | 12-07-2006 12:36 PM |
| Couple Questions | lukachuki | Masonry | 8 | 07-10-2006 09:34 PM |
