Contract For Pressure Washing
Old 04-06-2011, 07:56 PM   #1
knothead's Avatar
Trade: general
Rewards Points: 87
Anyone have a good contract for pressure washing? I have one for my handyman work but need verbage for pressure washing, I am quoteing a large job 41 unit town home complex not alot of surface area mostly single car driveways and a a short walk by each door 20 foor max from sidewalk.
But want some protection if i get a window wet and they get mad about it.
knothead is offline
Old 04-07-2011, 08:35 PM   #2
Supahflid's Avatar
Trade: Commercial Waterproofing, Masonry Restoration
Rewards Points: 254
Re: Contract For Pressure Washing
Hey knothead, if you post in your own thread, at least you'll have one reply! Oh wait, now you would have two!
The only thing I know to tell you is that you should carefully note all existing conditions in your proposal and make your proposal a part of the contract. I'm sorry I can't be of more assistance; I don't make the contracts that I sign, but I always try to include our bid day proposal as a part of any contract.
Supahflid is offline
Old 04-07-2011, 10:40 PM   #3
fireguy's Avatar
Trade: Fire Suppression Equipment Sales & Service
Rewards Points: 324
Cars moved out of work area, animal removed, lawn and patio furniture moved. OHA supplies water
fireguy is offline
Old 04-09-2011, 08:16 AM   #4
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
Rewards Points: 54
Include expectations;
Not all gum will be removed, color of surface may be inconsistent, damaged or spalled surfaces will be exposed, and subject to repair, tenants are responsible for closing windows, removing anything that may get damaged, keeping pets and children away from work area.
Include hours of operation, who supplies water, who is responsible for waste water/effluent. include noise consideration and limited access to areas being worked. include your provisions for safety tape, signage, and notifications.
Kevin
www.BadcoDoors.com
Pearce Services is offline
The Following 2 Users Say Thank You to Pearce Services For This Useful Post:
aptpupil (04-25-2011), Roofcheck (08-25-2013)
Old 04-09-2011, 10:19 PM   #5
knothead's Avatar
Trade: general
Rewards Points: 87
Thanks for the tips good ones
Well not everyone looks here every day so I was prepared to wait a few days for a response.
Looks like it got the bid without the fine details, had to drop $400 off my price since another company under bid me, but till I have that sig./deposit it not 100%
knothead is offline
Old 04-22-2011, 05:31 PM   #6
knothead's Avatar
Trade: general
Rewards Points: 87
OK done and completed it took 3.5 days made some good coin, talked to the president of the strata he liked the job I did
did a little sales pitch to have the complex done every year and to get 41 back yard patios cleaned off.
New question as a result of my good work here I am quoting a 3 story building deck only job. But I will need to use ladders and I cant use the stand offs due to the placements of the windows to decks. Plus in some places I will only be able to put the ladder against railings. I have seen the pads to go on the ends that will work in most spots. BUt when I have to the ladder on a rail I dont want to take the finnish off of nice shinny rails. I was thinking i glueing a pad onto bottom side of the ladder.
suggestions???
knothead is offline
Old 04-24-2011, 10:38 PM   #7
delhamas's Avatar
Trade: Deck Builder & Refinisher
Rewards Points: 25
Knothead, you don't need to use a ladder to wash the sides of the deck including the railing. The ladder is a way to get on to the deck. From there, simply lean over the hand rail. The skirt or outer joists will need to be done via ladder or some kind of lift.
delhamas is offline
Old 04-25-2011, 01:39 AM   #8
fireguy's Avatar
Rewards Points: 324
x-jet
fireguy is offline
Old 04-25-2011, 08:26 AM   #9
delhamas's Avatar
Rewards Points: 25
Cleaning hoses and decks are not the same. An X-jet will not get the job done.
delhamas is offline
Old 04-25-2011, 01:03 PM   #10
knothead's Avatar
Trade: general
Rewards Points: 87
Thats correct I am not washing the building only the deck floors. I hav eto get onto each deck to do the cleanup. SO suggestions for rail protection are still needed. I will be buying a new ladder as my old one is not tall enough for the 3rd storey it would be nice if I could use a man lift/cherry picker but no room too many trees.
Here is the complex they spent a small fortune fixing leaks I really do not want to screw up all the work.
Contract for pressure washing-west7th.jpg   Contract for pressure washing-west7th1.jpg
knothead is offline
Old 05-12-2011, 04:08 PM   #11
knothead's Avatar
Trade: general
Rewards Points: 87
OK I figured out my own solution for protecting the guard rails I glued strips of cloth to the bottom side of the ladder rails with PL400 and it worked perfectly and did not interfer with extending the ladder one bit. When it was wet it did allow the ladder to slide a bit easier but I would tie the ladder off every time.
Here are a couple pic of the complex and one of the worst decks I had to clean. The after pic is not that great it was over cast and raining but in person it looked great.
7 days and 78 decks on 3 levels ( some double size) myself and a helper.
knothead is offline
Old 06-21-2011, 12:15 AM   #12
House Painters Reading PA
4thGeneration's Avatar
Rewards Points: 250
Why was your quote $400 more than the other company and did you actually see the estimate from the other contractor. I mean if you have a legitimate reason why your more expensive I would not go down on price unless I can see the other estimate to compare apples with apples.
Colonial Power Washing and Painting by Sutton provides
House Painting Services in Reading PA
for all Interior and Exterior Projects
484-334-1311
4thGeneration is offline
Old 07-10-2011, 11:10 AM   #13
knothead's Avatar
Trade: general
Rewards Points: 87
Never did find out but I got the job and several others. With the equipment I have and upgrades I have made to the tools I have I am making some serious coin. I made up for the $400 on the next job with ease.
I will mention that never never never allow anyone else to estimate your sq footage. My guy subs to me and he "measured" tow jobs and he was off by 2000q ft on one and 1500 sqft on the other. Now this guy is a contractor /estimatator I assumed that he could use a walking measureing stick wrong. I have to eat it but I will addin a few extra on each of the next jobs to make it up.
Next week i am doing a 4000 sq ft tennis court using a new vac/swirly setup to remove the water as I sweep should be intresting.
knothead is offline
Old 08-25-2013, 06:37 PM   #14
B-dog's Avatar
Trade: pressure washing / Marketing
Knot, if I might call you that. Good job.
Not only did you have the insight into the possibility of getting more work but you had the intuition that you weren't working for a opportunist.
$400 bucks, without seeing the other bids... I call that customer service.
They had to have told you to come down by $400. And you said yes Sir.
Opportunity sometimes costs money, and it always pays off in the long run in dividends or education. Both worth it.
On the contract question, here's my two cents.....A little coin thrown at a contract lawyer pays off big and you have a valuable business resource to show for it.
B
B-dog is offline
Time To Really Consider Escalation Clauses Ed the Roofer Business 19 02-17-2017 10:25 PM
Storm Chaser Acting As Adjuster AND Using Contingency Contract Found Illegal In Il Ed the Roofer Roofing 6 01-24-2011 03:55 PM
Customer terminates contract snowflake Business 15 06-09-2009 10:51 AM
Contract and terms. AFI Painting & Finish Work 28 09-29-2006 06:57 PM
