Trade: HandyWOMAN
Cleaning Concrete Driveway
What kind of solution are you using to clean concrete driveways?
Thanks, Pat
Pat Harris A HandyWOMAN Service, LLC "Why call a handyman when you can call A HandyWOMAN? |
Custom Builder
Re: Cleaning Concrete Driveway
Muriatic acid, rubber gloves and a good stiff brush.
Bob |
Trade: contractor
muriatic acid to clean concrete bob???
it'll clean it alright .... |
Custom Builder
Who needs 4 inches anyway.
![]() It's a good thing neither of my ex-wives could use that line.
Bob |
Trade: Pressure Washing
General dirt,grease,oil,rust?
Muratic is bad,bad,bad without just cause.
Karvonen's Pro Clean Pressure washing/Low pressure roof cleaning 229-776-7856/229-344-5596 Scott Karvonen |
#6 | |
MFWIC
Trade: house painter
Re: Cleaning Concrete DrivewayQuote:
If nothing really serious the stuff at HD for your pressure washer will do just fine. Wet it down first, then apply detergent, then spray off. Acid IS dangerous! Not unless you must etch the surface as prep. r |
Trade: Trenching, Grading, Drainage, Fencing, and more!
Here are a couple of jobs I did where I just used direct pressure from my machine to clean the concrete.
http://www.geocities.com/allenh1970_4/felder http://www.geocities.com/allenh1970_3/LaCour That Felder job wore me out!!!
You don't know half, until you know all" - My quote Fulcrum Services, LLC www.fulcrumservicesllc.com |
#8 | |
contractor
Trade: power washing - new construction and restoration cleaning
i would stay away from the muriatic acid. most of your driveways you can get by using an industrial grade degreaser with some industrial grade bleach. If acids are required i would suggest britenol HD or GSR from eaco chem it also kills the mildew and algae for longer lasting results. Prosoco also makes some pretty good basic cleaners. but i prefer eaco chem. we also have several different flat surface cleaners, which if you do enough flat work will definately pay for themselves.
Gutter Clean & Power Wash Hickory, NC Last edited by tom connelly; 07-31-2008 at 01:48 PM. |
contractor
Re: Cleaning Concrete DrivewayThat would be extremely time consuming, and labor intensive. Last edited by tom connelly; 08-05-2008 at 11:03 AM. |
Trade: pressure washing/low pressure roof cleaning
It really depends on what you are removing. If its just dirt, mildew and some tannin stains you can use a bleach and soap mix. Hot water will help too.
owner
Trade: Hanging, Taping, Custom, Repairs, Scrapping
tear it out and re pour
contractor
thats a great idea...if your in the pouring business.
contractor
muriatic acid will etch your surface. If its not properly applied, you can also have other problems such as rust stains from the rebar, heavy acid burns, and so on. I've seen some really nasty sites. Some of the problems may not all be immediate either, and they may be near impossible to fix. Play it safe, not just for the concrete and the environment, as well as surrounding surfaces; but also for yourself and your customers, stay away from raw muriatic. You can achieve not just great, but better results without it.
| The Following User Says Thank You to tom connelly For This Useful Post: | Supahflid (04-01-2011) |
SEALERGUY
Re: Cleaning Concrete Driveway Not to mention all that acid in your face. Plain old pressure does a nice job, if you dont have a surface cleaner, double back both directions to avoid zebra stripes.
DECK-TECHS-MICHIGAN-DECK RESTORATION-BRICK PAVER RESTORATION- |
Trade: Grounds maintenance
Re: Cleaning Concrete Driveway |
#17 | |
many thanks Last edited by williammwill; 05-30-2011 at 03:26 AM. |
#18 |
ACME
Trade: Pressure Washing, Power Washing, Steam Cleaning
Hot pressure washing is best and will usually do the trick. Detergents and chemicals can also be used for particulary stubborn oil, stains and grime on the concrete surface. As mentioned above, the rotating surface cleaners are your best bet to avoid zebra striping.
#19 | |
Trade: Decking
#20 |
Trade: masonry/hardscaping
I can only assume, Pat, has finished the job by now.
But, to throw in my two cents, a good P.W. should take care of most of the general cleaning and since nobody mentioned it in the past 4 years, throw a can of coke on the oil stains and let it work while you use CLR on the rust stains. Then go back and hit the oil stain with the P.W. Done deal. Clean up. Get paid. Go home. D.
" ROCK YOUR WORLD " |
| pouring concrete on gravel driveway | 72chevy4x4 | Concrete & Paving | 5 | 01-02-2008 10:31 PM |
| Cleaning concrete off of mixer. | Michaeljp86 | Masonry | 25 | 07-08-2007 11:11 AM |
| Cleaning concrete | S.W.C | Masonry | 9 | 10-25-2006 08:03 PM |
| concrete driveway finish standards | henryr | Masonry | 10 | 04-29-2006 06:53 PM |
| Concrete Driveway Demolition | Sir Beamer | Excavation & Site Work | 11 | 04-06-2006 05:47 PM |
