Bleach???
Old 07-29-2008, 03:35 PM   #21
Handle It!
MALCO.New.York's Avatar
Re: Bleach???
Originally Posted by zukkoor View Post
Well it is not straight NaOH that is just the active ingredient and it is concetrated. The product is called Powersolve. I have used it for five years and it does not strip any color out of the deck.
+ YouTube Video
http://www.youtube.com/watch?v=V3FnpaWQJO0
Ultimate Wisdom---------
MALCO.New.York is offline
Old 07-29-2008, 05:31 PM   #22
contractor
tom connelly's Avatar
Trade: power washing - new construction and restoration cleaning
Re: Bleach???
If it works with great results and you and your customers are happy with it - great. Some of the wood care products we use have the same ingredients, and they are excellent. That is the main ingredient of my favorite wood cleaner as well. I was simply referring to unbuffered chemistry.
Gutter Clean & Power Wash
Hickory NC
tom connelly is offline
Old 07-29-2008, 05:34 PM   #23
Handle It!
Re: Bleach???
Originally Posted by tom connelly View Post
If it works with great results and you and your customers are happy with it great. Some of the wood care products we use have the same ingredients, and they are excellent. That is the main ingredient of my favorite wood cleaner as well. I was simply referring to unbuffered chemistry.
Which he originally lead us to believe was being applied!
Old 07-29-2008, 05:43 PM   #24
contractor
Re: Bleach???
Yeah, thats why i wrote it.
Old 07-29-2008, 06:33 PM   #25
Handle It!
Re: Bleach???
This I know, Tom. I was just giving zukkoor a little grief!
Old 07-30-2008, 10:53 AM   #26
contractor
Re: Bleach???
Yeah, I know. Thats alright.
Old 10-09-2008, 09:20 PM   #27
name
User33836's Avatar
Re: Bleach???
I have been washing exterior homes for many decades now
and there are mnay tricks of the trade to use etc bleach is one of them along with a better way to apply it to the surface to make more time
i build my own pressure washer systems they work great and very good
there are other chemicals i sue also
that help out so much
good luck one thing i can say is find yuo an old house and try different methods to clean them that is how i learned alot from
robert
User33836 is offline
Old 10-09-2008, 09:22 PM   #28
Handle It!
Re: Bleach???
As opposed to "Interior Homes"?
Just ribbing the Newcomer!!!!!!!!!!!!!
Old 11-03-2008, 08:56 PM   #29
superdeez's Avatar
Trade: Handyman
Re: Bleach???
One product I love is called Simple Green. I'll buy the concentrate and then dilute it, lay it with a chemical injector, then wash it away with a wide fan spray tip.
Great results most every time.
superdeez is offline
Old 02-20-2009, 10:06 AM   #30
A1CC&PW's Avatar
Trade: Pressure Cleaning & Roof Cleaning
Re: Bleach???
SH all the way
Pressure Cleaning & Roof Cleaning in SW, FL
Licensed Insured
[Office] 941-270-0742 [Fax] 941-423-7891
A1CC&PW is offline
Old 03-07-2009, 04:20 AM   #31
Tampa
Roof Cleaning's Avatar
Trade: Roof Cleaning
Re: Bleach???
Most surfactants are NOT compatable with Bleach.
We are testing a TRULY Bleach compatable surfactant.
Our Tampa Roof Cleaning trucks are currently using it in our tanks.
More info here Roof Cleaning at the RCIA Forum
Be careful what you mix in with Bleach.
Dangerous fumes can result.
Apple Non Pressure Roof Cleaning Tampa
Roof Cleaning is offline
Old 03-07-2009, 08:51 AM   #32
Handle It!
Re: Bleach???
That being Ammonia.
Mixing with Lye (NaOH), does not create fumes but it does create a very large and dangerous amount of heat!
Old 03-10-2009, 11:30 PM   #33
EPPSLLC's Avatar
Trade: Power Washer, Roof Washing, Lawn Care, Landscaping
Re: Bleach???
never mix ANY acid with bleach
DJ Carroll ~ EasyProProperty Services
Power Washing ~ Landscaping ~ Roof Cleaning ~ Lawn Care
Louisville, Kentucky
The BEST property service company in the tristate area
EPPSLLC is offline
Old 05-01-2009, 12:49 AM   #34
House Painters Reading PA
4thGeneration's Avatar
Re: Bleach???
Never mix SH with ultra or concentrated dish soaps with SH. Do not mix oxiclean with SH.
Dawn Original only if you want a good surfactant with your SH, but I have to ask about your deck...
Type of wood
Current finish latex/oi?
l clear/semi/semi-solid/solid?
You need to clean/Strip/pH balance then coat after the moisture is out of the wood.
House Painting and Roof Cleaning by Sutton provides
House Painting Services in Berks county PA
for all Interior and Exterior Projects
484-334-3999
4thGeneration is offline
Old 05-01-2009, 10:21 AM   #35
Error Corrector
olyteddy's Avatar
Trade: Maintenance Manager
Re: Bleach???
If you look at the ingredients of that '30 Second' outdoor cleaner stuff you'll see it's mostly TSP and bleach.
When what you've got is a hammer
all your problems start looking like nails...
olyteddy is offline
Old 05-01-2009, 10:42 AM   #36
#1 stunner
Static Design's Avatar
Trade: Design/Build
Send a message via AIM to Static Design
Re: Bleach???
adding fuel to the fire...
I use a special mixture of bleach, borax, dawn,shock it, and water. I actually use it for vinyl siding and just experimented it on a deck one day and had fantastic results, so that's what I use now.
Static Design is offline
Old 05-01-2009, 02:48 PM   #37
Re: Bleach???
As far as the TSP goes you have to be careful because it can etch glass. When it dries if not properly rinsed off you will have to scrape it off.
House washes I use Dawn, 12.5 SH, Sodium Metasilicate and a few other goodies to kick it up a notch.
484-334-3999
Old 10-03-2009, 06:52 PM   #38
plazaman's Avatar
Re: Bleach???
Im sure your machine has a downstream injector.... forget about store bleach. its weak and cutting it 50% is weaker! Find yourself a pooly supply or chemical distributor and get fresh 15% Sodium Hypoclorite
http://www.pressuretek.com/ and order the simple cherry house wash , you also have to order a few special tips that allow you to shoot your chemicals high. Call Them.
Mix that up in a 5 gallon and down stream, let it dwell for a few mins and low pressure rinse.
No need for TSP unless you are doing paint prep.
plazaman is offline
Old 10-03-2009, 06:54 PM   #39
Handle It!
Re: Bleach???
You mean base!
Old 10-20-2009, 09:11 AM   #40
TheCleaningDoc's Avatar
Trade: Websites SEO
Re: Bleach???
On a deck that neglected like the one I did recently, I used the sodium hydroxide based stripper because it has such thick crud on it and then followed up with a citric and oxalic acid combination.
Pat Motz
406-465-9334
TheCleaningDoc is offline
Drywall Dust Cleanup BlueCrabContrct Drywall 16 03-22-2009 02:48 PM
bleach and jomax Robert S Painting & Finish Work 12 06-20-2008 08:32 PM
New Decks Forum! Nathan Decks & Fencing 27 04-22-2008 08:49 PM
Pressure Washing Paint Prep with Bleach plazaman Painting & Finish Work 14 08-06-2007 09:09 PM
how to bleach the red oak??? anyone!! zuza_vincent Flooring 10 06-08-2006 10:53 AM
