Bleach???
Old 06-17-2008, 08:29 AM   #1
woodchuck2
woodchuck2's Avatar
Bleach???
I just took on a job of pressure washing a wrap around deck and washing the home that is sided with T1-11 and surrounded by Pine tree's. The home has sat for approx. 12-15 yrs with no maintenance so the deck and siding are dark with mildew,moss and are starting the process of decay. I usually use Crud Cutter or a deck wash to clean with but i had a fella tell me to use Clorox cut 50% with water to bleach the wood. He says to rinse the wood, lightly spray on clorox, let it sit for 15 minutes and the wash it off with low pressure water. He claims it will remove all the grime and bleach some color back into the wood. Have any of you folks heard of this or used this method? I will be staining the house and deck when it is done but the owner is looking for a lighter finish. I told him no guaranties due to the lack of maintenance and condition.
woodchuck2 is offline
Old 06-17-2008, 08:36 AM   #2
Any Season's Avatar
Re: Bleach???
Krud Kutter is a great cleaning agent but I always use bleach, and this year I started subbing out my washing for homes we are painting and he uses bleach also. Especially when you factor cost into it, cut to the chase and go with bleach.
Any Season is offline
Old 06-17-2008, 09:17 AM   #3
General Contractor
Giftcard's Avatar
Re: Bleach???
Some cities don't allow the use of bleach.
Giftcard is offline
Old 06-17-2008, 10:10 AM   #4
Handle It!
MALCO.New.York's Avatar
Re: Bleach???
Bleach..................But 2:1 (50%) sounds a BIT strong. A wee bit!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 06-17-2008, 04:59 PM   #5
woodchuck2
woodchuck2's Avatar
Re: Bleach???
Thanks for the replies fella's, i will try the bleach then. I guess i will be wearing white those days . The deck is approx. 850' square and the house is approx 2000' square.
Old 06-17-2008, 07:44 PM   #6
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Bleach???
Back when I was involved with this kind of stuff house hold bleach was frowned upon and was the mark of a hack. There was a pressure washing or a deck restoration forum I belonged to and they all seemed to not be fans of house hold bleach for very substantial reasons, which I can't recall the specifics now. It seemed to me if I recall right they all were using some sort of special oxegenated bleach or something like that, I think it was more like a hydrogen peroixide sort of thing. You might want to look into it a bit before you go thowing house hold bleach on it.
I found the link to one of the sites: http://www.deckcare.org/forums/index.php
I don't know that much about it, but I thought you might want to know a little bit more.
Mike Finley is offline
Old 06-17-2008, 08:12 PM   #7
Handle It!
Re: Bleach???
Oxalic Acid is the "Wood Bleach".
Old 06-18-2008, 01:06 PM   #8
contractor
tom connelly's Avatar
Trade: power washing - new construction and restoration cleaning
Re: Bleach???
That doesn't sound like a good idea if you ask me. Besides how do you bleach color back into wood?! Bleach strips the colors and sugars out of the wood leaving it dry and faded looking. Bleach will surface kill the mildew but remember bleach doesn't remove stains it simply makes them invisible, it also deteriorates the wood by eating the lignens in it. Besides that 50% is way to strong. Personally I'm not to fond of Crud Cutter either, but it sure beats bleach.
Bleach is not recommended, unless you are using an oxygenated bleach blend as specified above, a sodium percarbonate or something of that nature.
EFC-38 by ESI is a very good cleaner, that will outperform your standard percarbonate cleaners every time.
Call Russell from Extreme Solutions and talk to him.
Russell # 1-636-288-8512
Gutter Clean & Power Wash
Hickory NC
tom connelly is offline
Old 06-18-2008, 08:03 PM   #9
Chief Toilet Mover
Re: Bleach???
That's the one!
Old 06-19-2008, 09:23 PM   #10
woodchuck2
woodchuck2's Avatar
Re: Bleach???
Thanks for the info guys, my brother-in-law refered me to a cleaner from Cabot formulated for this very condition so i may opt for that instead. I will check out the tips you have offered too, Thanks.
Old 06-20-2008, 04:41 PM   #11
ccpc's Avatar
Trade: Pressure Washing & Roof Cleaning
Re: Bleach???
The bleach debate in wood care is an issue that has been on going since wood care began.
I am a proponent of using bleach to clean wood that has been neglected for a long time. An oxygenated bleach is good for light cleans, but you will find that it will not work very well on a deck that has major build up. This will require something much stronger.
If the wood has an old failing stain or sealer, you may need to consider using a stripper.
Lance Powell
Clay County Pressure Cleaning, Inc
Pressure Washing Florida
Roof Cleaning Jacksonville
ccpc is offline
Old 06-22-2008, 06:07 PM   #12
contractor
Re: Bleach???
Cabot cleaners are alright but they will eat you up in cost and time. You can do a better cleaning job with less time and money using extreme solutions cleaners. You can also use EaCo Chem's cleaners as well, they are very effective, and if used properly will save you lots of time and money.
Hickory NC
Old 07-20-2008, 02:50 PM   #13
PRO
Blackhammer's Avatar
Trade: CGC Concrete
Re: Bleach???
I have not used bleach in any of my PW's because I heard it eats the seals in the pump. Is this true or just BS?
Blackhammer is offline
Old 07-20-2008, 03:36 PM   #14
General Contractor
Giftcard's Avatar
Re: Bleach???
yes
Giftcard is offline
Old 07-22-2008, 11:56 AM   #15
Tampa
Roof Cleaning's Avatar
Trade: Roof Cleaning
Re: Bleach???
Not if you downstream it.
Just don't run bleach through the pump
Apple Non Pressure Roof Cleaning Tampa
Roof Cleaning is offline
Old 07-22-2008, 12:36 PM   #16
Handle It!
Re: Bleach???
Brass and rubber really, really, REALLY do not like the Oxidizing powers of Bleach.
Old 07-28-2008, 04:29 PM   #17
zukkoor's Avatar
Trade: Decks
Re: Bleach???
I use sodium hydroxide I have found that it actually cleans the wood and does not bleach it you get a much more natural color when you are done and it is much stronger than bleach. just be careful because it burns your skin.
zukkoor is offline
Old 07-28-2008, 07:03 PM   #18
Handle It!
Re: Bleach???
Lye....Drano.....NaOH, is a MoFo.........Careful
Old 07-29-2008, 12:06 PM   #19
contractor
Re: Bleach???
Unbuffered Sodium Hydroxide will also eat the lignens out, and with time your deck will degrade, it too will strip the natural oils out of the wood. It works great, but you need to expand the molecule so that it will not penetrate into the wood fibers, causing damage. The less damage you cause and the less sugars and oils you strip out of the wood, the less stain you will use, because you are not having to replace all of the natural oils that you have just stripped out. Thats why you want to avoid raw unbuffered chemistry.
The chemical cost of stripping and brightening a deck is around 2-5 cents a sq.ft. the cost of a stain is about 15 cents a sq.ft. It makes more sense to spend more on chemical to spend less on stain, as the price difference is so dramatic. Besides you will have a much better looking deck that will last longer.
Hickory NC
Old 07-29-2008, 02:57 PM   #20
zukkoor's Avatar
Trade: Decks
Re: Bleach???
Well it is not straight NaOH that is just the active ingredient and it is concetrated. The product is called Powersolve. I have used it for five years and it does not strip any color out of the deck.
zukkoor is offline
Drywall Dust Cleanup BlueCrabContrct Drywall 16 03-22-2009 02:48 PM
bleach and jomax Robert S Painting & Finish Work 12 06-20-2008 08:32 PM
New Decks Forum! Nathan Decks & Fencing 27 04-22-2008 08:49 PM
Pressure Washing Paint Prep with Bleach plazaman Painting & Finish Work 14 08-06-2007 09:09 PM
how to bleach the red oak??? anyone!! zuza_vincent Flooring 10 06-08-2006 10:53 AM
