4 Sale: 1/2 HP Wayne Porta Pump
Old 04-18-2007, 10:43 PM   #1
Terrence's Avatar
Trade: painting and carpentry
Ok guys, heres the deal. Many of you know it flooded around New Jersey, and I was one of the unlucky ones to take on some water. Since we have no sump pump, I had to go buy a utility pump to get the water out. I bought the pump Monday, April 16th, used it monday night, and have no use for it any more. I thought if any of you do power washing, or have any other liquid moving needs, you might find it useful. I pumped 6,485 gallons of water, and it worked like a charm.
It is in brand new condition, and has been used carefully, and only once. I will provide the receipt of sale with the unit. It's a handy (I'm guessing... didn't measure) 5" x 8" x 10" size. Because it is a cast iron impeller housing, it's surprisingly heavy for it's size, so it should be rock solid. To prime the pump, pop the plug off, and put in about 30 oz of water or other fluid. After priming, just connect a hose to each end, and plug it in!
For Sale
Wayne Porta Pump Model #PC4
I paid $202.66
Hoping to get $160 for it.
Here is what the box says:
1/2 HP motor pumps up to 1450 gallons per hour
Boosts water pressure as much as 40 psi for power washing
3/4" brass adapters connect to standard garden hose
Rugged cast iron construction
Drains Flat Roofs
Removes water from boats
Washes cars, vans and trucks
Water lawns and gardens
Rids basements of standing water
Empties and fills stock tanks
Manufactured by
Wayne Water Systems
100 production Drive
Harrison Ohio
Call 917-363-4687 if you want to make an offer or have any questions.
Terrence is offline
Run a Heat Pump on solar power SR Martin HVAC 173 11-20-2010 12:38 PM
Irrigation pump pressure switch mdshunk Landscaping 10 12-04-2006 09:39 PM
American Standard Whirlpool pump bad? nobody Plumbing 5 11-07-2006 10:28 PM
Well Pump Depth Question... thepawnshop Plumbing 9 08-13-2006 09:01 PM
What Pump to Use? dblommel Painting & Finish Work 0 03-05-2006 12:15 PM
