Originally Posted by plazaman
First, off, No i dont want to use the xjet with the 100' hose.
which brand of hose 100' should i get? whats the deal with marking and non marking. i see ebay has some pretty decent prices on hoses.
X jet, have a 4gpm 3800 unit i see 2 different versions of this products?
which should i purchase? i see they have the original and newer version.
thanks.
First off, why wouldnt you use 100' of pressure hose with your Xjet?
Second You really should pay the extra money for the grey non marking hose, Because when you are dragging your hose accross the clean concrete you just cleaned, your going to have to go back, and touch up those spots.
Third I personally use the Xjet M5 you lose a little distance compared to the original, but you dont have to change nozzle for short and long distance, Just twist and go.
The xjet will pull 30-35% chemical, So mix about 3 gallons of SH and 2 gallons of water in a 5 gallon bucket and you will be good to go.
check out,
envirospecnorth.com
They have great prices
John
