Zone Valve
Old 03-04-2009, 06:30 PM   #1
Marc D's Avatar
Trade: electronics
Zone Valve
I have a Honeywell zone valve V8043A1185 that looks faulty. I checked the voltage to the valve and can manually open it so it seems to work. I'm guessing that the motor or powerhead (I think it's called) is bad. Can I change this without draining the water or doing any soldering? Any help would be appreciated including where to buy the part in the Northeast if possible.
Thanks, Marc
Marc D is offline
Old 03-04-2009, 06:46 PM   #2
manager
greghvacguy's Avatar
Trade: heating cooling tech
Re: Zone Valve
This is not DIY site so we can not help here sorry
greghvacguy is offline
Old 03-04-2009, 06:48 PM   #3
mdshunk's Avatar
Re: Zone Valve
The heat motor (powerhead) quarter-turn clicks off the valve body. No draining necessary. The heat motor has to be cool before it will release, however.
mdshunk is offline
Old 03-04-2009, 06:58 PM   #4
Paul B's Avatar
Re: Zone Valve
I sorry you feel this way. I am general contractor and have knowledge of a lot of thing. Sort of a jack of all trades, master of non(not exactly). But you get my drift. I hope you never need info about something other then HVAC.
Paul B is offline
Old 03-04-2009, 07:48 PM   #5
tgeb's Avatar
Re: Zone Valve
Originally Posted by Marc D View Post
......... where to buy the part in the Northeast if possible.
Thanks, Marc
Google "Honeywell zone valve V8043A1185" I found a half dozen places that sell that valve. Or go to your local supply house with the valve number. They'll have it.
www.gebcon.com
tgeb is online now
Old 03-05-2009, 09:03 AM   #6
22rifle's Avatar
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Re: Zone Valve
No, I'm sorry YOU feel this way because the site owner has said this is not a DIY site.
So if you want to deny reality... then be my guest but it makes me sad to see you do it...
22rifle is offline
Old 03-05-2009, 09:31 AM   #7
Marc D's Avatar
Trade: electronics
Re: Zone Valve
Thanks to mdshunk, Paul B & tgeb for your support. I found the motor is bad and I'll replace it on my own. You other guys, well, nice to know you're there willing to help people. Hope you're never in this position.
Marc D
Marc D is offline
Old 03-05-2009, 09:57 AM   #8
22rifle's Avatar
Re: Zone Valve
Marc D
snicker...
22rifle is offline
Old 03-05-2009, 01:06 PM   #9
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
Re: Zone Valve
the v8043 model has a seperate powerhead assemble that can be replaced without unsweating the pipes. the E model has 4 wires, 2 yellow, and two red. the F model has 5 terms. the previous comment about a heat motor is incorrect, those are for BG and taco models. 1 or 2 screws hold the powerhead onto the valve body. get the right head and replacement is a snap.
NickTech is offline
Old 03-05-2009, 01:08 PM   #10
NICKTECH
NickTech's Avatar
Re: Zone Valve
some home depots actually have it
NickTech is offline
Old 03-05-2009, 07:19 PM   #11
mdshunk's Avatar
Re: Zone Valve
The OP added the valve mfgr and model after I posted. I (wrongly) assumed that it would be a Taco. That's what I mostly see.
mdshunk is offline
Old 03-07-2009, 01:33 AM   #12
manager
Re: Zone Valve
I was just flowing form rules. I took it as you where a diy.I do HVAC and know how to use a hammer and nail.I dont go on sites asking how to build a wall.If I need a wall built a call a carpenter to do it.If you where a general contractor then you would have a hvac company that you use that could help you out so took it as a diy and as this is a open site any one could resd it and try to take it off and some of the honywell zones whould open the head to water. so turn you boiler on and get it real hot and hope it will not spray all over you and if it does then you will no when its not working when you get burnt.One last thing there is general contractor out there that dont know $h1t and would run to the other side of building if I saw them with a tool in there hand.Then I would call 911 to get them on there way because he will hurt him self or someone. So have a good day I was just following the SITE RULES
Old 03-07-2009, 02:16 AM   #13
BigMikeB's Avatar
Trade: HVAC
Re: Zone Valve
Nope sorry an 8043 has two screws that hold the motor and the motor can be replaced easily, if you pull the four corner screws to change the whole head you will open the water side up and be pretty unhappy if you didn't drain the loop first.
The Veto toolbag, the Louis Viton of tool transport. The official toolbag of rich guys.
BigMikeB is offline
Old 03-09-2009, 01:16 PM   #14
NICKTECH
NickTech's Avatar
Re: Zone Valve
the motor itsself as well as the powerhead assembly can be changed. the better solution is the whole powerhead assembly. if the motor went the other parts could be next. cheap insurance that way. the whole powerhead can be removed with out entering the water side of the system. 2 screws hold it to the rest of the brass body. the 4 corner screws are not accessable with the assemble on, once its removed then there seen however further disassembly is not needed at that point. always follow safe work practices and ensure the boiler is off and cool, as an extra precaution one could depressurize the boiler to less than 8 psi w/o draining it. this job is too easy. hope this helps. oh....home depot and other supply houses have the zone valves as well as tissues for you other bit<hes crying about helping someone.
NickTech is offline
Old 03-10-2009, 11:36 PM   #15
Marc D's Avatar
Trade: electronics
Re: Zone Valve
Thanks guys I'm all set. Just replaced the motor and everything is working fine. Thanks again.
Marc
Marc D is offline
3 zone system propertyone HVAC 5 02-19-2009 06:42 PM
Help with a Moen Shower Valve thom Plumbing 33 01-11-2009 10:32 PM
reversing valve clicks osborn HVAC 2 08-23-2008 07:35 PM
how do troubleshoot a Honeywell Zone valve? bugdoc@linkny.com HVAC 9 12-01-2007 06:36 PM
Problem with Kohler k 304 valve....Help!!! gitnerdun Plumbing 11 10-12-2007 10:57 AM
