Wood Burning Insert Questions
Old 01-29-2009, 01:17 PM   #1
BAMAHANGER
jhall's Avatar
Trade: wallcovering installer
Question
I have a buck stove insert I would like to use.Concerned about my situation. My house was built with intention of having a fireplace.Masonry from ground up,huge rock wall with hearth and firebox with fire brick.NO Chimney,the brick are capped off with a 4'' cement slab.Behind these brick and rock is a walk in closet.The brick are framed in so you cant see them inside the closet the slab is exposed.Wondering if it would be possible to put a stovepipe adaptor on the insert and go through attic, out roof with stovepipe or class A.Not sure of clearances of insert and pipe,and studs that might be against fire brick.Also not sure about how to cap the firebox off to make it safe.Stove has blowers on each side,but I think the top is probably the hot spot?Had my local stove dealer/installers come out and look,but I dont think he knew as much about it as me.Ive read many posts here,think many of u guys know alot more than them.Im new to this site and slow on the keyboard,but getting better.I would welcome any advice.My local man said I could do it but im not so sure he is really qualified.
jhall is offline
Old 02-04-2009, 10:14 AM   #2
BAMAHANGER
jhall's Avatar
Re: Wood Burning Insert Questions
Thanks for the help.0 replies!Whats up?Thought you GIRLS knew a little something.
jhall is offline
Old 02-05-2009, 03:34 PM   #3
Paul B's Avatar
I think you are not getting replies because folks don't understand what you are saying. Where is the 4 inch slab? What do you mean no chimney, never seen a fireplace without a chimney.
Paul B is offline
Staining a new wood floor, questions.. Dorman Painting Painting & Finish Work 29 10-27-2009 06:51 PM
Wood floor refinishing Floorwizard Flooring 25 01-26-2009 10:17 PM
energy star rated wood door?? Century Man Windows, Siding and Doors 0 01-14-2009 05:37 PM
Buckled Wood Floor LNG24 Flooring 2 11-17-2008 11:35 PM
wood deck question ???? davinci Decks & Fencing 30 10-02-2008 07:07 PM
