Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 09-28-2009, 03:45 PM   #1
Trade: Drywall Finishing
Will a 6" 90deg elbow cause heat loss
Builder ran a 6" duct on my garage ceiling (will be spray foamed) to a vent that will heat the bedroom over my garage. My ??? is if i re-root that 6' duct and add 1 or 2 90 deg elbows will it effect heat flow to the above bedroom?
tonyvlx is offline   Reply With Quote
Old 09-28-2009, 03:50 PM   #2
Yes.
neolitic is online now   Reply With Quote
Old 09-28-2009, 06:21 PM   #3
Thom
thom's Avatar
Yes.
What he said
thom is offline   Reply With Quote
Old 09-28-2009, 06:29 PM   #4
Trade: Construction
If i remember correctly a 90 elbow has the same amount of loss as about an extra 20" of duct. Im sure a expert will know the exact amount.
BCConstruction is online now   Reply With Quote
Old 09-28-2009, 06:57 PM   #5
On 4" vents, every standard 90º elbow
adds the equivalent of 15' of straight pipe.
Old 09-29-2009, 05:48 AM   #6
Trade: HVAC
You'll lose some air flow for every ell you add.
Hope that pipe is insulated.
beenthere is offline   Reply With Quote
Old 09-29-2009, 06:58 AM   #7
special ed
Trade: builder home improvements
I've have been told that it is the same as 10' of pipe on 6" pipe
EIDOL is offline   Reply With Quote
Old 09-29-2009, 07:07 AM   #8
I run more 4 than 6, so I remember
that one better.
Old 09-29-2009, 10:25 PM   #9
NICKTECH
NickTech's Avatar
Trade:
Send a message via AIM to NickTech Send a message via MSN to NickTech
the 6" elbow, set up in a 90 deg config will provide the eqivilent friction loss of 6 ft of duct. if the equivilent length is below 100 ft the loss in air volume will be negligeable. how ever exposed in an unconditioned space the heat energy will be drawn from the duct wall reducing the amount of energy delivered to that room. adding an elbow or so and some duct isnt the problem i think, its keeping the heat in the duct. insulation...insulation...insulation!
NickTech is offline   Reply With Quote
Old 09-30-2009, 05:01 AM   #10
Trade: HVAC
I need a new chart. Mine says 10'
So adding 2 ells. One several foot from the other will add 20 of equivalent length.
If 2 90° ells are installed together in an S configuration it increases to 30' of equivalent length.
Considering that the lowest take off EL is 15', and the average right angle end boot is 35'(50' without any pipe yet). Adding 2 ells will significantly lower air flow.
Old 09-30-2009, 01:55 PM   #11
NICKTECH
NickTech's Avatar
Trade:
it'll be lower relative to the desired cfm output, the question was heat loss, not air flow, even though of course loss of air flow reduces btu output. the drop in flow wont change the temperature of the air, but an uninsulated area will. i think thats what was asked, right?
Old 09-30-2009, 02:16 PM   #12
Trade: HVAC
His question deserves the full answer.
The longer the air is in the duct, because of lower air volume, the more BTUs that air will loose. So it will probably change the air temp at the grille.
So it will be a 2 fold effect.
Old 10-01-2009, 07:27 AM   #13
Trade: renovator
All theoretically valid, except in the real world I highly doubt the builder optimized and balanced the ducting layout so perfectly that some sort of hvac nirvhana is going to be ruined by adding a single 6" ell.
Add a single ell, you'll get a tiny bit less airflow, which means a tiny bit less heat delivered, and the smidgen of extra back pressure will cause a minute increase in air flow at other registers, but, frankly, on your average hvac system the difference will be un-noticeable.
Add 4 ells, or if that branch is already iffy, and maybe you've got another story.
bob_cntrctr is offline   Reply With Quote
Old 10-01-2009, 12:56 PM   #14
Trade: HVAC
More like. The average has bad air flow from day one. And adding a single ell just makes a bad supply run worse.
ISO Report, P & C Industry Posts $1.3 billion 1st Qtr Loss, Will It Affect Businesses Ed the Roofer General Discussion 0 06-30-2009 02:27 PM
Building inspector requires me provide a heat loss estimate sampatil12 General Discussion 3 04-14-2009 02:02 PM
heat pump jdager HVAC 2 01-31-2009 04:17 PM
Heat loss calculations Paul B HVAC 6 09-15-2008 05:56 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 03:38 PM
