Union Electrician
Trade: Inside Wireman
Whole House Humidifier
Is there such a thing made that attaches to your furnace that will humidify the hot dry air blowing out of the furnace?
If so, what are your thought's on these units and about how much do they cost? -joe |
#2 | |
Trade: Squirrel Handler
Re: Whole House HumidifierQuote:
http://www.aprilaire.com/index.php?z...category=humid $130 to $350 on Amazon. http://www.amazon.com/s.html/ref=pd_...&index=blended Last edited by mickeyco; 02-17-2007 at 02:54 AM. |
you can pick up a couple of different sized units from Lowes or HD-less than $200 for a unit sized for a 2000 sqft home.
Trade: Diesel Fitter
Keep it clean, these things are breeding grounds at least the older units were. Late spring /fall at least! these problems may have been addressed but who knows. You may want to upgrade your filtration.Children are at higher risk.
Union Electrician
Isn't there some sort of adjustemnt for the amount of water it puts in the air?
I'm about used to the dryness now, but my poor dog is almost hairless, well not quite, but he scratches way too much. |
Yes, they have a control on them for that purpose. You can also get a freestanding humidifier at Sears, for instance, if you are a renter. That might work well for you.
Trade: hvac tech
Hi sounds like u need a flow thru humidifier april aire 550 [depending on house size] with a humidistat which acts like a thermostat and will come on with the heating if its calling for humidity the only thing is a floor drain is required,or maybe a condensate pump.installed somewhere aroun 5 or 6 hundred. good luck
Union Electrician
I am just renting, but depending on how difficult it is to install I'll just yank it out when I leave. Are they a complex setup? or just a hole in the duct and a water line?
I haven't ckecked if there's floor drain, but the water heater is in the same closet, would that also require a drain by code? For having it installed, my baby bro is a tin banger. He doesn't know much yet, but I imagine he could ask someone for a favor. Otherwise I can always find someone on the job site that'd do it for a few beers. |
| Did you see Flip this house - Cat House? | SuperiorBuilt | Off Topic (Non Trade) | 18 | 01-24-2011 05:17 PM |
| Frost inside the attic? | SOSSW | Roofing | 22 | 04-03-2009 08:26 AM |
| House moving | Toolwh@#e | Excavation & Site Work | 10 | 10-21-2007 11:23 PM |
| `Flip This House' star accused of fraud | AmeliaP | General Discussion | 28 | 06-03-2007 10:21 PM |
| Funding for first spec house? | ruskent | Business | 28 | 01-17-2006 08:10 PM |
