Who To Trust?
Old 06-09-2004, 10:44 PM   #1
HOME OWNER
Guest
HOME OWNER's Avatar
Posts: n/a
Angry
Who To Trust?
4 Year Old Trane Xe90 And Xb1000. Was Told By One Company Coils Need Replaced = $1000.00 (live In Ohio) Pressure At210psis/85 Only Bottom Of Coils Sweating. Second Estimate Stated Needed To Replace Compressor $600. Wanted The Pro's Thoughts And Ideas On What To Believe And Is There A Way To Get Trane To Warrant The Stuff? Warranty On The Unit Xe90 (coils) Is Only One Year. Compressor Xb1000 Is Covered That Cost Is Just Labor.
Old 06-09-2004, 11:06 PM   #2
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
Re: Who To Trust?
Hmmmmm only part of the coil is sweating and those kinds of pressures sounds like a restriction in the coil not a compressor issue. It could be plugged at the metering device (either fixed orfice or TXV) and if that is the case, they will generally frost up just past the metering device. IF some debris have passed through and is lodged in the coil, gonna play h*** trying to get it out and insure it won't happen again. In that instance ruling out metering device then I would have to agree with changing the coil. You might try another Trane/American Standard dealer for another opinion/quote.
HVAC Doc is offline
Old 06-11-2004, 10:21 PM   #3
scottkirty
Guest
scottkirty's Avatar
Posts: n/a
Re: Who To Trust?
thanks for your help. will get one more look at from trane certified company.
Old 06-27-2004, 01:26 AM   #4
nikko's Avatar
Re: Who To Trust?
I would agree on getting another tech out to see whats going on.Hard to diagnose without outside temps etc.etc.I'd rule out metering device.Your suction pressure would surely be in a vacuum if this was the case...Good luck
nikko is offline
Need advice in Nebraska drywall1127 Drywall 3 04-22-2007 11:35 AM
Trust yer gut feeling reveivl General Discussion 8 03-02-2007 11:08 AM
Quality and Trust, or Bad Scheduling? MKamis General Discussion 9 11-20-2006 03:17 PM
Roofer vs. Roofer (Just a long winded hypothetical) Thunder1 Roofing 7 12-01-2005 10:22 PM
Fiduciary mikesewell General Discussion 14 04-05-2005 11:41 PM
