What Type Of Thermostat
Old 08-16-2009, 11:10 PM   #1
Old Crow's Avatar
Trade: General Contractor and Remodeling Contractor
I have a trane heat pump and a oil furnace each with there own thermostat, that type of thermostat do i need? what brands do you all reccomend and could i install it or does a pro need to do it? Thanks!
Old Crow is offline
Old 08-17-2009, 10:55 AM   #2
flashheatingand's Avatar
Trade: H.v.a.c.
Re: What Type Of Thermostat
I would go with the honeywell setup. It's not something you can pick up at HD, but at a local hvac supply house. I don't know your knowlge of wiring controls, but in general, it would be best to get a hvac guy to install it. If done incorrectly, a lot of time can be wasted.
Good luck
flashheatingand is offline
Old 08-17-2009, 08:41 PM   #3
Old Crow's Avatar
Thanks for the info. I was looking at a Honeywell VisionPROŽ IAQ Thermostat would this work for my setup? Its for my own house but i will probably have it professional installed.
Old Crow is offline
Old 08-17-2009, 09:44 PM   #4
Trade: H.v.a.c.
Yeah, the Vision-Pro is the type I recommend. A little pricey, but seeing as this is a 15-20 year investment, it's worthwhile. (easy to say when it's not my money)
Old 08-18-2009, 10:40 PM   #5
Old Crow's Avatar
Thanks. I will start searching the net.
Old Crow is offline
Old 09-11-2009, 06:22 AM   #6
beenthere's Avatar
Trade: HVAC
You have a separate heat pump, from the oil furnace?
As in the heat pump has its own air handler.
You'll need someone that knows how to add relays to use the Honeywell IAQ,. or any of the Vision pro models.
beenthere is offline
Old 10-04-2009, 09:46 PM   #7
Miller257's Avatar
Trade: HVAC
i have vision pros in my house, and usually put them in on most jobs.
Miller257 is offline
Old 10-05-2009, 04:51 AM   #8
beenthere's Avatar
Trade: HVAC
They are a nice thermostat.
But. Still need a relay system. To use it on a heat pump with its own air handler, and an oil furnace.
Old 10-06-2009, 10:25 PM   #9
Trade: H.v.a.c.
Granted, it's been two months since that post, and I totally misread that. I was under the impression that it was one air handler. I still think there is one air handler. I can't imagine two air handlers with one duct system. But, it does say two seperate t-stats. I hope the coil is in the return...
I wonder how they set it up originally.
Dramatically Increase Your Sales Home Services Marketing & Sales 29 05-07-2009 12:42 PM
Thermostat question kbsparky HVAC 7 03-08-2009 12:31 PM
Thermostat Wiring Help GoodHouse HVAC 2 03-05-2009 05:47 PM
Can I split thermostat wire??? Jambruins HVAC 5 01-13-2009 06:29 PM
Single pole vs. double pole thermostat dforeid Electrical 2 10-23-2008 10:42 PM
